Dry mix or wet concrete for ballast box
   / Dry mix or wet concrete for ballast box #12
I do not understand using concrete (wet or dry). Just use sand or whatever you have laying around. That way you can reduce the weight or increase the weight as needed. Personally I would use sand so I end up with a "flat" top area. Leave a few inches below the lip of the box and you have a place to put tools and what not.
Put a PCV pipe in the box vertically so you have something to put a shovel or rake in.
   / Dry mix or wet concrete for ballast box #13
:stirthepot:
Isn't the curing reaction exothermic? So at least some mass leaves as heat... Lol.
   / Dry mix or wet concrete for ballast box #16
   / Dry mix or wet concrete for ballast box #17
I think even that is only a few kilos! Lol. Just stiring the pot.
Oh I understand that completely. Of course now you got me curious as to how much matter is actually destroyed in an atomic bomb. The estimate for Hiroshima is that 7/10 of a GRAM of uranium actually underwent fission reaction and was converted to energy. Yes that is seven tenths of a GRAM. A dollar bill weighs just about a gram.
   / Dry mix or wet concrete for ballast box #18
:eek::eek::eek:
   / Dry mix or wet concrete for ballast box #19
I have also considered adding scrap steel or lead, but the cost makes that less reasonable.[/QUOTE]
This is my future "box" when I get time to melt it. one cubic ft. = 707.96lbs. (scrap lead from restoring old stained glass windows) have about a ton of it
   / Dry mix or wet concrete for ballast box #20
I think the rest is just needed to obtain critical mass. :confused3: It is truly amazing. Can you imagine the "nuclear bomb deniers" that would exist today?!
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2016 Chevrolet Tahoe SUV (A55973)
2016 Chevrolet...
