Snow Front snow plow with hydraulic angle change question
   / Front snow plow with hydraulic angle change question #11
Run hoses from the plow angle hydraulics to the loader quick disconnects for the bucket circuit. Make a pair of hoses to connect to your existing bucket curl circuit hoses that are newly disconnected to your rear remote hydraulic valve. Use the rear remote valve to make the occasional adjustment to blade tilt. Use the bucket curl function on the joystick to angle the plow left & right.
   / Front snow plow with hydraulic angle change question #12
Thirsty, I visualize your ideas, I think. With the bucket off the curl cylinders are sitting there with nothing to do. Set op some QDs on the hoses if necessary and then use the 2 curl hoses to power the tilt system on the plow. One control to work with. Joy stick then; up/down on the blade and left/right on the blade angle. A lot easier than reaching around for a rear mounted valve. You will want to devise a means to support the curl cylinders from flopping around. I am sure you are ingenious enough to handle that.
Ron
   / Front snow plow with hydraulic angle change question #13
I use the bucket curl function a lot on my front snow blade. One use is for pushing up banks when the snow starts to really pile up. By curling the blade while raising I can pile the snow higher. Another thing is tilting the blade when backdragging away from my garage doors. I tilt the blade so its not riding on the skids and get it cleaner right to the door. Also, since I have the ability to tilt easily, I vary the angle when I really want to get the most loose snow off my snow packed driveway. I ran the angle adjust from the SCV on my L5740 but got a third function on my new L6060. Running from the SCV was not a problem - I got the third function more for my grapple which was inconvenient running from a SCV.
Thanks everyone for your thoughts. I finally made a decision. I'm going to run hoses from my rear remotes to the snow blade angle cyllinders. I measured for the hoses today using an old garden hose. 23' for each of the two hydraulic hoses. Longer than I thought. I plan to use 1/4" hydraulic hose for maximum flexibility. I think this will operate the cylinder fast enough. It is not a very big cylinder.
Is 1/4" big enough?
One more question, this one with pictures....
I know how to connect and disconnect the type of quick disconnect shown in this photo. You just pull/push back the knurled sleeve and the fitting pops apart.
I'm a bit confused on the ones in the following picture. I can push them together, but how do you get them back apart?
Thanks.
   / Front snow plow with hydraulic angle change question #15
Is 1/4" big enough?
Yes, its perfect-I've sold several setups like that.
As to the remotes you pictured, they are called "breakaway" style, with them you just push in and then pull out quickly and sharply, the male nipple will pop right out.
Thanks KennyD.
   / Front snow plow with hydraulic angle change question #17
I got a 3rd function on my new L4060. Have yet to fix up an old truck plow (or more likely now get a new or newer SSQA plow) to mount on it though.
If you have extra rear hydraulics, you can just run a long hose pair up front to run angle or other stuff. The OEM QD operate mostly like the standard ones, except they are mounted by the sleeve rather than the back of the fitting. Pull on the hose & the sleeve stays put & fitting moves causing the hose to pop free like moving the sleeve on standard fittings. Same for connecting. It's really nice & can be done 1 handed unlike standard fittings. Also likely to disconnect on its own properly if forgotten or an impliment falls off. I wouldn't trust it for routine use though as it might jam due to alignment issues. Always manually disconnect if possible.
PM me & I'll try to get the hydro diagram out of my Lxx60 WSM.
   / Front snow plow with hydraulic angle change question #18
I have a set of lines running from my rear remotes to the front of the FEL. I set mine up with quick connects at the point where the loader arms pivot on the frame, the place that the large pin goes through to pin the loader on the tractor. This allows me to leave the lines to the front of the loader in place when I remove the loader. The lines to the front can be run through the loader arms this way.
I operate my grapple with this set up and I have operated a hydraulic power angle for a blade when I used a FEL set up for the blade.
One thing to keep in mind is that the power angle cylinders are single action cylinders. All you need to do is hook one hose to each piston and the hydraulic pressure from one cylinder will push fluid back through the valve from the other cylinder.
   / Front snow plow with hydraulic angle change question #19
Only semi-related... That fact causes problems if you try to use a diverter & your loader valve only does regen (like all the economy Kubotas). Regen dumps full pressure to both hoses. On your bucket dump the but end of the cylinder having more surface area than the rod end will overpower the rod end. Dumps faster because of the extra fluid coming out of the but end & also prevents worn seals from sucking in air as the bucket pulls on the cylinders faster than the pump can fill em. 2 opposing single action cylinders just push against each other equally & do nothing when hit with regen.
   / Front snow plow with hydraulic angle change question #20
Bit late to the thread as it seems you already have your mind set, but a few things worth mentioning.
1. No need to detach the backhoe. Just unhook the hoses. The concern then becomes the boom drifting down. Double check your manual. I could be wrong, but I have yet to see a backhoe that didnt have a place to chain the boom up. You are actually supposed to do that when transporting or driving down the road. On the main boom, about mid way up should either be chain hooks or keyhole looking slots that a chain will grab into. The same should be on the ends of the outriggers. Raise boom and outriggers up all the way and chain as short as you can. Then lower the boom (preferably with gravity and tractor off) to take the slack out of the chains. If you dont do this, the boom can drift and you might have a hard time recoupling the backhoe if those couplers arent a connect-under-pressure style.
2. What type of plow are you going to use? There are basically two types, rigid SSQA types, and converted truck plows that have a chain lift. For gravel or rolling drives, the chain type is the preference. Because without a chain to allow ONLY the plow to float, you are either going to be constantly adjusting, or putting the whole loader in float. Which dont work real well as the whole tractor tries to drive up over the loader, and you loose steering. Have you ever tried to Float your loader bucket going forward? Now imagine that happening when plowing.
3. A pair of SA cylinders like a truck plow normally has is preferable. A few reasons. 1. You will have equal angling speed. A single DA cylinder will be fast one way, slow the other. 2. Equal angle force. Same as before. A DA cylinder will be weaker one direction and stronger the other. 3. The ability to use a crossover relief. You CANNOT use a crossover with a single DA cylinder. Well, you can....but it aint gonna do squat. If you catch something with the edge (side) of the plow, and the cylinder isnt already fully retracted, you put a heck of a pressure spike in the hoses and cylinder. Hit something hard enough and you pop a hose. Think about a floor jack. You have a handle that is pumping a little rod that builds pressure and raises the jack. Well the plow is the handle and the cylinder is the little pumping rod. You have alot of tractor/weight, and with some speed and leverage, its easy to pop a hose. Which would be a big concern of mine using the rear remotes....just depending on where you route the hoses. (Right beside you?) The crossover relief protects against this by dumping oil from one cylinder to the other once a certain pressure is exceeded. But they only work with two cylinders of equal volume. A Single DA cylinder has differing volumes.
4. Have you considered a diverter or third function? I did a diverter setup on mine and a joystick for the loader with a button. I had just a tad over $300 for everything but doing over again, it would have been cheaper because I would not have used the expensive flat face 1/2" couplers. I would have just used 3/8 or 1/4" couplers similar to what snowplows already have. All I run is a grapple and a plow, no need for massive couplers.
There are links in my signature regarding a diverter install, as well as a truck plow conversion to use on a tractor. Truck plows are a dime a dozed compared to SSQA plows
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2020 FREIGHTLINER M2 26' BOX TRUCK (A57192)
2020 FREIGHTLINER...
UNUSED FUTURE MINI EXCAVATOR WOOD GRABBER (A57193)
UNUSED FUTURE MINI...
ATLAS MD785 7' ROTARY MOWER (A57192)
ATLAS MD785 7'...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
40' High Cube Multi-Door Shipping Container (A56469)
40' High Cube...
