Mowing Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE???
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #101
I'm planning on getting a 2015 or newer DK10 series Kioti... Is there an oil cooler on this model, or a recommended way of adding one?
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #102
Just don't abuse it and all will be well.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #103
How about a temperature gauge?
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #104
Sounds like a simple case of too much cutter for too little tractor compounded by a somewhat weak design... A cutter of the size described needs 70-90HP utility tractor.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #105
Not true. I mow with a 8' all day long on a 51hp (42pto) if I had 70-90hp I'd be pulling 12'.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #106
Why are oil temp gauges not standard and what's the best method for installing one? Seams like a great idea if one wants to put his tractor to work.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #107
He needs a hydraulic trans temp gauge. However both can be added with fittings that can be gotten from you gauge supplier. Some use drain plugs. My FIL drilled and tapped the side of his trans case where there was room and tapped and installed. I have even seen dip stick ones - hot sure how well they work, There are also surface mounted ones. Just do a good search of you application.
Hope this helps
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #108
Tis true here in the foothills especially if you use your tractor for multiple uses like running turning plows in this red clay.
200 Gallon Tank (A57148)
200 Gallon Tank...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2014 Kia Optima Sedan (A56859)
2014 Kia Optima...
