What size cutter for an M7060?
   / What size cutter for an M7060? #1
Herkypilot
Meadows of Dan, VA
Kubota M7060 HDC12, KX040 & L3540 HST
I recently purchased a M7060 after having run a 6 foot 3pt BushHog behind an MX5100 for the last 5 years. The dealer said he wouldn't recommend anything bigger than an 8 foot pull type behind the M7060. That doesn't sound right to me - I'm thinking up to 12 foot batwing. Maybe something like the LP RC2512. I have moderate hills to mow. What do you all think?
HP
   / What size cutter for an M7060? #2
71h.p. and they don't recommend more than 8 foot pull behind sounds crazy.
   / What size cutter for an M7060? #3
HP
In my mind, that 12 footer would be the perfect mower. :thumbsup:
Yes, and they have to order the 8 footer so it's not like he's trying to sell something on the lot.
I'm looking at the Bushhog 1812 Flex wing which is 3200 lbs and the LandPride RC2520, 2500 lbs Both are rated at 1-1/2 maximum cut
The Bushhog looks pretty stout which I suppose accounts for the added weight.
HP
   / What size cutter for an M7060? #6
LandPride is owned by Kubota. Seems like there should be some charts to see recommended attachments.
   / What size cutter for an M7060? #7
Over the seven years of owning the M6040 I seen a lot of varied opinions on maximum implement size for my tractor. My owners manual - which also covers the M7040 - recommends 84" and 1200# as being max size rotary cutter for both M6040 & M7040.
My concern has always been - to get a heavy duty rotary cutter - example Brown or Bush Hog - its not so much the PTO HP that limits my choice as it is the companies recommendations for maximum implement weight. I guess it has a lot to do with how "hard" you will be using the implement.
Anyhow - I continue to muddle on and, I guess, one day I may purchase a rotary cutter.
BTW - your Operators Manual for your new M7060 should have a page titled - "Implement Limitations".
   / What size cutter for an M7060? #8
It will easily pull a 12', foreman Etexas pulls one with his M7040. His is a pull type though.
   / What size cutter for an M7060? #9
what is the pto hp requirements of the LP RC2512? what is your pto hp, around 62-65? then take into consideration heavy growth, etc. & be ready to keep the blades sharp. that's where i'd start does that batwing model require 2 remotes? do you have 3 for good measure? good luck
   / What size cutter for an M7060? #10
im running a 12ft batwing commerically with no issues. Any thing that is really tall and think I just slow down a little ForumRunner_20150718_172030.pngForumRunner_20150627_071738.png
2004 AGCO Gleaner 3000 Corn Header (A55315)
2004 AGCO Gleaner...
2011 JOHN DEERE 544K WHEEL LOADER (A52707)
2011 JOHN DEERE...
UNUSED FUTURE 350 HYD EXCAVATOR BREAKER HAMMER (A57193)
UNUSED FUTURE 350...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2013 Chevrolet Silverado 3500 Ext. Cab Animal Control Truck (A55852)
2013 Chevrolet...
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
