What happens when I follow the manual for the cold weather start procedure 3038e
   / What happens when I follow the manual for the cold weather start procedure 3038e #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
This is my first winter with my new to me 3038e, the owners manual says to put the range lever in low and turn the key to start position for X seconds, then move the lever to neutral and let it start. It does not say what is going on in the machine. Does this activate an internal heater? All I can figure it would do is push the diesel real tight to the injectors. What goes on when this start procedure is followed?
John
   / What happens when I follow the manual for the cold weather start procedure 3038e #2
I suspect an internal heater.. the service tech manual should spell out the function and procedure to tell what is going on.
The heater is on the intake manifold with four bolts and a wire attached.
   / What happens when I follow the manual for the cold weather start procedure 3038e #3
On my 4110 that is how the glow plugs are activated
   / What happens when I follow the manual for the cold weather start procedure 3038e #4
Glow plugs
   / What happens when I follow the manual for the cold weather start procedure 3038e #5
No glow plugs in the 3038e.. just the intake manifold heating element, (item #5 in attached).
That explains it, thanks beenthere!
   / What happens when I follow the manual for the cold weather start procedure 3038e #7
Apparently the cold weather starting procedure is different depending on the serial number and engine type. Only the older models with the Yanmar 3TNV84T require the low-range to neutral process.
S/N (010001-609999) North American , Yanmar 3TNV84T - Low-range to activate heater
S/N (610000-710000) North American , Yanmar 3TNV86CT-NJT - Neutral to activate glow plugs
S/N (710001-) North American , Yanmar 3TNV86CT-NJT - Neutral to activate glow plugs
   / What happens when I follow the manual for the cold weather start procedure 3038e #8
That appears to only be true for the older 3TNV84T engine. 3038e models with the 3TNV86CT-NJT have glow plugs (item #37 below).
   / What happens when I follow the manual for the cold weather start procedure 3038e #9
jgay
The OP will need to check that out, to identify his setup.
Mine is about 6-7 years old, the first or second year made, bitter cold out right now to check the serial number, will do tomorrow.
I do find it unusual that with the long 40+ year history of glow plugs that they would introduce a new model without them and then add them later, makes me wonder what was going on in the North American Engineering Department.
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2844 (A58376)
2844 (A58376)
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2014 Chevrolet...
