New GC1710
/ New GC1710 #1
zski128
Northeast, MA
2016 MF GC1710
Hello,
After 6 months of research I have finally pulled the trigger on my first tractor a couple weeks ago. Looking at all the brands local including Kubota, Deere and Mahindra I decided on the GC series and was lucky to have a great dealer about 1 hour away. I did check out the GC1720 but felt that the extra cash was not worth the fancier seat and other minor add ons. I have been really impressed with its capabilities for its size and have already dug out a small stump and buried a large boulder. This is my first time using a TLB and its taken some practice to get used to controls with 3 hours of seat time so far. This forum has been a great tool while researching the various brands. Hopefully I will have knowledge to contribute the more seat time I get.
Some things I have ran into so far.
1. Watch your FEL hydraulic lines when closing the hood. One of the lines got tucked in behind the hood and started to chafe a little. I poped the hood and pushed/bent in the sheet metal a little so now it closes a little tighter to the bottom of the console.
2. Had a pretty good hydraulic fluid leak on one of the FEL lines. There was a small puddle on the deck after one day. One of the fittings was only finger tight. Hopefully that does not return.
3. The HST seems weak on hills or small obstacles. I made a small dirt ramp into part of property, probably about 1-2 foot incline over 6 feet and I need to get a running start to make it up. I am in low gear and also tried 4x4 with the throttle in the green zone on the tach. Works fine on flat ground. I am familiar with HST operation but something doesn't feel right.
Thanks for reading.
Rich
/ New GC1710 #2
Congratulations and welcome.
I've had my GC for 5 years and although I want to pick something up that is too large, I can attest that this scut is a great tractor and has served me well.
I have put more seat hours on in the last few weeks due to the snow we've received than the same time in the summer. Love it!
/ New GC1710 #3
Rich That doesn't sound right about not climbing a small ramp in low gear. The only time I've had the hst bog down is going up hills in high or medium. You may want to give the dealer a call. Also check the hyd oil level, maybe that leak made you loose more oil than you thought.
/ New GC1710 #4
Agree^^^ In my experience the GC feels like a whole different agile animal with the backhoe off but still has the power to climb beyond its capabilities (to the point of flipping backward) with the backhoe on.
/ New GC1710 #5
Best wishes for you with your new tool!
I'm equal with you in history. Please get some anti-gelling additive for your fuel if you have not already done it. Most auto parts stores and the home depot stock it. There are a lot of great tips on this site.
/ New GC1710 #6
Just an fyi. Most hst's have less power the more you press down. Next time you try going up the ramp let off the pedal some and see if it picks up speed. That's how my ck20 was.
/ New GC1710 #7
hydrostat in mine seems to still work okay with over 500 hours on it.
I do spend most of my time in low range though. pretty well all the bucket work you do will be in low range, high range for traveling, but it's easy to go back and forth between hi and low once you get the hang of it. if the lever is binding, just give either one of the hydro pedals a little feathering.
have fun, and keep the wheels on the bottom side.
Making the digging a little easier - YouTube
/ New GC1710 #8
Ditto mpham! HSTs are a bit weird in that regard. If you google how they work, it might make it easier to understand, but it's certainly true that, when climbing, less pedal works better than more pedal. I know, counter-intuitive, but that's just the way it is. But-- by all means if that doesn't help it climb better, call that dealer!
Oh- and congrats on yer new tractor. Those little GCs are very capable!
/ New GC1710 #9
Congratulations! I just did a 50 hour service on my GC1710. Great tractor!
/ New GC1710
Thanks everyone for the helpful advice. I am familiar with hydrostatic transmissions and how they operate but something does seem off. If I try to start on a hill I have to roll back down and try again, the wheels dont spin like I lost traction, I just get a whine from the system. Even when backscraping with the FEL, if I get the front wheels off the ground a bit when I don't want to use float I don't go anywhere, pavement or dirt. I checked the sight glass and its still showing color (not white) so I dont think the system is low. Will be contacting the dealer this week to take a look.
/ New GC1710 #11
almost sounds like you are traveling with the park brake on, I still forget it every now and then. wouldn't hurt to familiarize yourself with the sound of the death whine of your brake.
/ New GC1710 #12
I rarely throttle into the green and I have been able to push large boulders up steeper/longer slopes with my GC 1705. Even without rear weight. I am pretty sure some of the final assembly and QC is done at the dealer so they may have missed some adjustment or test. You definitely have a problem that needs dealer attention during warranty. Would be curious to find out what the problem and resolution turns out to be.
/ New GC1710 #13
I would say something isn't right, my 1705 will climb just about anything with a 450lb bush hog and loaded tires at 2200rpm without issue..
/ New GC1710 #14
What RPM are you trying this incline with?
/ New GC1710 #15
He said the 'GREEN' range which is well above idle. I have a GC1720 and although it definitely has more torque with a light pedal than a full mash, I have never had it unable to move EXCEPT with the brake on - then that HST whine is awful.
/ New GC1710 #16
Then something is not right. I use my 1710 in the mountains a lot at 10,000 ft about sea level. Most engines need all the help they can get at that altitude, and my 1710 goes up and down my logging roads in low with little throttle.
/ New GC1710
After testing the tractor more I believe I found the issue. I don't think I had it shifted all the way into low gear. The range gear lever was not going all the way back and took a bit of playing to get it moving smoothly. I now feel a detent and the level goes further back. Running up slopes and over other obstacles is much better now. Thanks to everyone for the suggestions.
/ New GC1710 #18
And if you really want traction. . . Step down on the diff. Lock. If your lo/hi shift catches just a bit. . Shift to hi then neutral and tap the forward pedal just a bit. . Then it should shift smoothly to low.
/ New GC1710
Haven't messed with the diff lock yet, the 4x4 works pretty good though. Not sure if this is the same for everyone but when I try to shift into low range and release the parking brake I need to let off the brake pedal then push it down again or I cant fully shift into low range. The shifter just stops like its bound up. Going into high works every time as expected.
/ New GC1710 #20
sounds like a trip to the dealer may be in order, if you can't see any obvious problem with the linkage... no sticks/branches stuck up between anything?
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
New/Unused Spirit Electric Bicycle (A65583)
New/Unused Spirit...
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2008 Volvo VNL Sleeper Truck, VIN # 4V4NC9EJ98N489293 (A65563)
2008 Volvo VNL...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
