Battery Maintainer - Good/Bad/Ugly?
   / Battery Maintainer - Good/Bad/Ugly? #31
Battery Minder will allow you to hook several batteries in parallel for charging / maintenance. A few bucks more --- but works!! I have two, one for tractor / Rtv/ mower, other for vehicles.
Buy cheap ---- pay twice / By good ---- pay once!
JW5875
   / Battery Maintainer - Good/Bad/Ugly? #33
You guys are really good at helping spend a guy spend money.
That's the 2nd most important function of TBN... helping to keep the economy going. Right behind providing useful tractor knowledge & wisdom.
   / Battery Maintainer - Good/Bad/Ugly? #34
Wow, that looks like quite the good setup for Solar battery charging for sure. Just need to add the Solar panel to it.
Steve who uses Ctek chargers with Desulfation... I've been doing a long term test on our FarmPro 2420 Tractor battery to see how long it will last with the Extreme charger on it (military grade). I've posted the results from time to time so far in the Chinese tractors forum.
This looks interesting... Desulfation feature is nice.
http://www.batteryminders.com/12-volt-solar-battery-charger-SCC-180
   / Battery Maintainer - Good/Bad/Ugly? #35
I have a battery charger that has 2amp/10amp/50amp settings. Can I use the 2amp setting to maintain my battery without purchasing a separate tender?
   / Battery Maintainer - Good/Bad/Ugly? #36
You need to look at the manual. If it just puts out up to 2@ at normal battery charging voltage, you'll end up wit a dead boiled battery in the not to distant future. It needs a smart mode where it will drop the voltage down when it's charged & kicking back up a little when it detects it discharged a bit.
   / Battery Maintainer - Good/Bad/Ugly? #37
Fallon's point about overcharging your battery is vital! That's why I don't leave batteries on my crude little HF trickle charger more than days at a stretch. I worry about zapping them. I wonder if there's a simple way of monitoring battery condition, as with a voltmeter?
   / Battery Maintainer - Good/Bad/Ugly? #38
You can use a cheap timer and just have it hit the battery for an hour a day.
   / Battery Maintainer - Good/Bad/Ugly? #39
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
