Removing fence posts with concrete
/ Removing fence posts with concrete #21
I would wait until the ground is plenty saturated. Certainly not now knowing that TN has been in a drought. What is the plan going forward? If you are replacing the posts with new, you would want to pull the concrete out, maybe break it up with a sledge for backfill. If your are not replacing the posts then you might want to break the concrete as you pull the posts for backfill so it won't take so much soil. Drilling a sidehole will work but if you are putting in new posts then you are in for a lot more tamping.
Your loader bucket will work just fine. Use a foundry hook on the post end so it chokes the post and grabs hold. Sometimes you need to wrap the chain twice if it's slipping. Go by the tractor sounds and the post. No verticle movement then you need to rock the post some more. Using a helper will make for a much easier job.
/ Removing fence posts with concrete #23
I have always thought a brush-grubber could be repurposed for pulling out wooden fence posts. I suspect the spiked jaws could be modified for metal posts.
/ Removing fence posts with concrete #24
So, did you get them out yet?
TBS
No the posts are at my property 2 hours from where I live. I will be replacing a fence in front of my cabin that has seen its better days. I probably won't get started until early spring.
/ Removing fence posts with concrete #30
Bobcat and 4in1 bucket.
/ Removing fence posts with concrete #33
I removed a couple recently using the dig-a-hole-next-to-it-and-pull method. Works just fine. I also used a section of a log as a "wheel." Kind of combined two techniques, I guess.
/ Removing fence posts with concrete #35
Who is the guitar player?
Assuming you're talking about my avatar ... that's me a couple of years ago (2014?) when I was playing bass with RED - A Tribute to Sammy Hagar.
/ Removing fence posts with concrete #36
Back in 1969 I worked with a guy putting in chain linked fences and removed a lot of post in concrete. All you need is a come-a-long. Hook the come-a-long to the bottom of the post and hook the other end to the top of a another post and set the bottom on something sturdy and winch it out.
