restricting flow
/ restricting flow
Oh-
and Happy thanksgiving folks
/ restricting flow #22
May have to try a five foot long handle on those rascal valves.:laughing:
/ restricting flow #24
That's exactly what I did (well, same concept but a little shorter).
Rear remote levers on my Bobcat CT are stubby little things on a pedestal to the right of seat.
Too short to operate with any finesse.
They're round bar 3/16" or so with a plastic cap.
Removed the cap, threaded the ends and added a piece of 3/16 threaded rod and coupling to each. Cover back over the new end.
Think I added about 10" or so and it's a little too much but just haven't gotten around to cutting.
MUCH easier to control now and well worth the effort and minimal expense.
/ restricting flow
Just wanted to circle back with the end result, been traveling a lot for work so so time has elapsed
i got the fittings Brian had suggested all 4 at .031 orifice, i guess i am a little clueless but i did not realize i could just place them in-line till they arrived. With the .031 orifice i went from a sub 2 second cycle time on both rotation and spout to about 8 seconds- a little slow and i could really hear the engine load when i used the hydraulics.
I ordered some 3/64 bits (.047) as i could not find them locally, too, i got a drill press rig for a dremel as that was recommended for super small bits. they arrived, everything worked like a charm and i took extra pains to clean up all the fittings. Now cycle time is in the 3.5 to 4 second time frame which seems perfect- fast enough but not too fast.
Thanks Brian- good recommendations,
thanks
/ restricting flow #26
You can also find those fittings at Tractor Supply for anyone else that may want to use them and doesn't want to wait.
/ restricting flow
thanks Todd,
I will say the folks at Trausch seemed quite nice and i would not hesitate to give them addl business
I used my blower tonight for the first time since drilling the larger holes tonight and the swing time is almost perfect, Maybe 20% after might be ideal but i am not about to take it all apart for that, plus i am guessing the next bit size would speed it up a bit more than that. The valve seems to have some proportionality at the restricted flow so i guess i could go a bit bigger but really i am at the good enough stage.
Thanks all and have great holidays with people you care about.
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
Topsoil Trommel (A57453)
Topsoil Trommel...
207274 (A52708)
207274 (A52708)
2011 Cadillac Escalade AWD Crew Cab Pickup Truck (A61573)
2011 Cadillac...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
