Need grapple hydraulic help
   / Need grapple hydraulic help #11
Ditto regarding seals
BTW isolating the cylinder from the valve won't tell if the cylinder is bad. Because of the rod, even if the piston had no seals, you can't add "rod" to a full cylinder- their is no room. Read up and learned this one a few weeks ago.
Lifting the grapple to 90° and seeing if it drifted down quickly could indicate a bad valve.
Testing the cylinder involves installing valves and pressure gauges on either side of the piston and reading the pressure difference over time.
His drift is pulling the rod out of the cylinder.
   / Need grapple hydraulic help #13
On a Grapple the cylinder extends to close. Collapses to open. His drift is toward closing. So rod is moving out of cylinder barrel rather than into. It's possible for that to happen.
Open the Grapple. Then unplug the hoses. See if it drifts closed.
This will separate the cylinder from the tractor valves and will give you a better idea where the problem might be.
Another test, if the couplers are the same, would be to unplug the FEL Curl function hoses and plug your Grapple into that circuit. Test operation. This again would indicate cylinder problem or valve problem.[/QUOTE
Can only get one line to disconnect with pressure on the line. FEL connects are different.
With lever actuated to close lid it closes real slow but can be closed faster using my hands. Only with the lever actuated. Can't close by hand without the lever actuated. Would really like to isolate it to the cylinder before trying to tear it apart.
   / Need grapple hydraulic help #16
So it sounds like the valve is good. Without being able to move/switch hydraulic hoses it is difficult to give a definitive answer but everything is pointing toward the cylinder from what you describe.
Bench testing a cylinder requires a couple of gauges and shutoff valves. But removing the cylinder from the grapple shouldn't be too hard and someone around you I'm assuming can help if you don't want to open it up.
To get pressure off everything to disconnect lower everything to the ground and shut off tractor. Then run the valves in all directions this should release the pressure enough to disconnect.
   / Need grapple hydraulic help #17
I had similar problems with my grapple.
I have 3 rear remotes. I moved the connection a round several times, trying to find which one worked the best. Ended up getting longer hoses for my hydraulic top link. The movement of the top link was moving the grapple hoses to the point of causing them to disconnect.
I am sure that is not your problem, but thought it might be worth mentioning in case it is something your over looking.
You have some very knowledgeable help already helping you.
Listen to them and you will be able to work it out.
   / Need grapple hydraulic help #19
Sounds like you've got this so I'll step out.
   / Need grapple hydraulic help #20
I just read up on this a few weeks ago so it's new to me. Only thing I have is an ability to repeat stuff.....haha
Actually your idea about the FEL quick connects is what I'd do to test it- even if he has to unthread a few fittings.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
