Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #11
How about a 4WD front deck mower with a snow blower?
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #12
I think he is looking for a machine to do sidewalks that can be safely ran on the road with a fast road gear.
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #13
Yep, but he hasn't found one.
These would have to be trailered, but would probably clear driveways and parking lots as fast as a wider rear mount blower.
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #14
there have been some threads like this over at plow site and i believe the what i see claimed is that the john deere 3720 /3046 is the highest horsepower/ fastest road speed in a sidewalk width tractor- not sure if this is true as i don't know much about clearing walking walks but a bunch of guys there do- might be worth checking out
I can talk about a pronovost rear pull (inverted ) blower as i have a p-74 inv on my 3720. It works great for me - any wider or if i had deep wet snow often i would want more horsepower.
here's a video of that blower on a 3046r Inverted Pronovost On Deere 346r - YouTube
Hello,
I'm really in need of some advice from you experts!
Looking to set up an L4060 or L4760 for snow removal. Tractor needs to be narrowed to fit down a sidewalk. The series I'm looking at has decent road speed, which is a must as the tractor/machine will be roaded from site to site.
-Spoke with the dealer whom said we can narrow the stance with rims and tires, which would get us close to 54"-56".
-Looking into an inverted blower for the rear around 72", maybe 84" for driveways and smaller parking lots. We get wet snow more times than not, is an inverted a bad idea since you have to back over the snow in order to clear it? I was thinking a Provonost or something similar with an hydraulic edge on it to pull the snow out then blow it.
-For the front setup I need an option to setup a broom, plow, and snow blower. **The catch is the attachments need to be less than 60" in width, and I don't believe the sub frame quick hitch mount on the 40 series has any options for attachments less than 60" in width?
I don't want to run the attachments on the FEL as I've heard its cumbersome and not the greatest.
Can anyone please provide me with some information in order to set up this tractor narrow as mentioned and with a blower on the rear and snow attachments as mentioned for the front at less than 60"?!?! Any other options and information would be greatly appreciated. I've looked into Toolcats, Holder, we have (2) Ventracs, and looked into about every other option. Toolcat is ideal, just cant get it down below 60" in width. The Holder is too darn big for what we do and couldn't clear larger spaces very well as its narrow and meant for sidewalks and or really deep snow.
Thanks! -Chris
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #15
I concur, the JD 3000 series is notably slightly smaller than the Kubota L3560 & the rest of the grands. The L3560 has a ever so slightly smaller frame than the rest. The L4060 to the L6060 are all the same frame, just bigger engines.
Personally I find the Kubota grands to be a bit underpowered. Really surprised they don't offer a higher HP 3000 series. JD makes several HP ranges up to the mid or high 40s on a smaller frame.
I wish I'd gotten a L4760 over my L4060, but couldn't & still can't justify the extra $5k.
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #16
You should take your tractor to the dealer and have them dyno it.
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #17
At what I'm guessing is 5,500lbs + implement my 40 net HP L4060 roads better than my old 3,500lbs + implement with 30 net HP. I'm at 6,500' elevation which eats like 6-7 HP or so. I'm pretty sure my machine is running properly.
A turbo compensates for elevation to a fair degree. TYM & LS machines in this range are running turbos, but you need to go up several HP notches to get a turbo Kubota. I weighed that when I test drove em all & still decided to keep with Kubota. I'm not hurting bad for HP, I just road a lot & am impatient. If cost were less of an object I'd have shelled out the extra $5k for a 47 over 40.
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #18
I'm 44hp and 7k+ when I go down the road. I've never felt under powered.
   / Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #19
I took a quick look at tractor data and its looks like the 4060 weighs very slightly more than an identical 4240 and has 2 hp net less, add in roughly 20% loss for the altitude and you've got about 10 hp less for similar tractors so i would think you would see a difference.
for the op's use horsepower will be key as both roading and snowblowing eat it up
Deere 3720's are the fastest small framed tractor I believe. I also believe they can be setup to be under 60" wide which is a necessity for me? I want to stick with Kubota if possible as I own other kubota machines. I've heard mixed reviews on Kubota and heard Deere are superior. Who really knows though?!?
I think the Kubota M narrow series would be the best of both worlds..Fast and quite narrow stance. I understand having a tractor setup narrow lessens it's stability. I wouldn't be taking the tractor off road. Instead just clearing snow.
Anyone have futter thoughts?!
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
