LincTex
By the way, you have way too many tractors. :laughing:
That's just the ones that "run and drive". Got a lot more for "decoration"!
Hi , I have a new Branson 3520h with about 45 hours that I put on in the first 2 weeks of ownership . I have the loader and bh86 backhoe . I used it on one of my new home construction sites for trenching electrical , sewer and drain lines . I find the swing speed on the backhoe a bit slower than I'm used too , so I was running it at 2500-2600 rpm all day long . I found that it works better with the loader at this rpm too . The dealer also told be that it should be run at pto speed for the DPF . It ran perfect with lots of power the whole time . Also when I have it in my shop , It sure is nice when I start it up to get it out (or put it away) that I am not choking on nasty diesel exhaust , it has no visible smoke and no smell . (much better than the worn out bobcat loader and excavator that I sold , those two were heavy smokers lol)
Just my two cents
^^^ Loves the assspain of an unreliable tool ^^^
LOL! Just kidding. I agree that the exhaust of a Dee Pee Effed diesel tractor is as sweet as a breast-fed baby fart, but if the tractor is not used at full throttle and over a relatively short period of time plugs up to a point that the tractor strands you, then it is a FAIL!!! I should be able to use a tractor lightly without being punished for living in the US. Being the self-starting, problem-solver that the Texas public school system taught me to be, I'm modding it.
And seriously... The Texas public school system of the late seventies/early eighties was pretty damned good. I wasn't allowed to slack and was pushed toward the best use of my innate abilities. It's a shame that modern oatmeal-headed students are taught bullshiznit...
I also have the backhoe and have to admit that it's probably the best backhoe at this price point. Of course I'd rather be able to move and dig at the same time but those backhoes are more than double the price of a Branson *520 with a backhoe.
This one though has "voice control" for moving as long as you have an extra person sitting in the main tractor seat, who listens to your commands and executes them perfectly. That's meat-based voice-operated backhoe positioning. Meat-based technology is tried and true; proven over multi-millenia of real-world use. The only issue is that meat-based technology is universally unreliable and in societies where slavery is illegal, quite expensive.
Oh yeah , bplanton , let us know how you make out modifying the muffler
I bought a muffler at Tractor Supply and took the new mufler and the DPF to Bud's Muffler in Colorado Springs. The bend on the inlet to the DPF is so tight that he had to send the tubing out to get it mandrel bent and he also had to have the flange plates fabricated because they apparently aren't a standard size. The muffler cost about $30 and the shop work was $156; so my DPF delete kit for the 2015 Branson 3520H was under $200.
I dropped it off at Bud's just before new year's eve and they called today to tell me that it's ready. I told them no rush, so it took about ten days to get the work done.
My wife is picking up the muffler this afternoon and I will install it after work and take some pictures. I'll take some video too so you can hear the way it sounds with a muffler instead of DPF.
Did you pipe it up or have it still blowing toward the front (stock)?
...and he also had to have the flange plates fabricated because they apparently aren't a standard size. The muffler cost about $30 and the shop work was $156; ...
Neat!! If I did this to my 4720 could I then run my engine lower rpm then the crazy high one every one recommends.It sure burns a lot of fuel.
Thanks
Dan
Not any more noise just a little when it's working hard it bellars a little.
The only real difference now is it is a little louder,
So the DOC got clogged. He must use his tractor like I do. It runs for about 10 minutes most of the time. Not enough to heat up to burn up the soot. I was wondering if this would be a factor with the DOC design.
Scuse me for butting in but you are going to accumulate moisture especially in the winter in all your fluids doing that besides having DEF problems you mention.
You don't have to be excused for "butting in". This is a public forum and your comments are welcome!
As LincTex said, these tractors don't use DEF. They have a simple soot-cooker on them along with a logger that takes pressure differential measurements in the DPF and uses that information to light up an idiot light on the dashboard. There is no DPF regen cycle that modifies the fuel injection or anything like that.
Mine clogged up after 62 hours of pretty light use, which is what I use it for. I use mine mostly for the FEL and dragging a box blade down the driveway. Occasionaly I use the backhoe, but that's most rare. I never plow or bale or use any PTO so I am not a use-case for a DPF. I expect mine will get clogged regularly, so off it came.
