Seeking advice on welding hook to FEL bucket
   / Seeking advice on welding hook to FEL bucket #1
Captain Dirty
Eastern Mass
Goldoni 600, Kubota L45
I intend to weld a 3T Gunnebo style hook onto a 3/8 backing plate and then weld the plate to the top of my FEL bucket. The bottom of the hook flares to a flat base approx. 1-3/4 x 4-1/2". Gunnebo-Johnson's welding instructions, which are given in 6 languages, are cryptic. I gather that I should lay a 1/4" fillet (6mm "throat") along the sides of the hook with 7018 rod. Crosby's instruction differ but are clearer: Make a minimum of 2 passes with E-312-16 rod completely around the base to create at least a 5/16" fillet.
My original intention had been to tack with 6011 and weld with 7018. Would that be adequate? Even with curl I doubt I can exert 3T of force.
Secondly, welding completely around the base of the hook will leave a small, sealed space between the bottom of the hook and the plate. My experience has been that unvented spaces will "blow" the weld when one tries to seal them. Is it best to leave a small gap?
TIA,
Captain Dirty
   / Seeking advice on welding hook to FEL bucket #2
You're putting a lot more though into this than I did. I welded the whole thing with 7018 and it hasn't broken off.
   / Seeking advice on welding hook to FEL bucket #3
I would use 7018, and weld all the way around.
   / Seeking advice on welding hook to FEL bucket #4
Just get some 7018 and start welding..IMG_20121117_162424_854.jpgIMG_20121117_162438_547.jpgIMG_20121117_164305_653.jpgIMG_20121117_165303_772.jpgIMG_20121117_170314_242.jpg
   / Seeking advice on welding hook to FEL bucket #5
Can't argue with the three posts above, but I'm not posting pics of mine. There might be almost a 1/2 inch total of weld on mine that is that nice, maybe!
   / Seeking advice on welding hook to FEL bucket #6
TIA,
Captain Dirty
Stick with your intention to tack with 6011 and weld out with 7018. That is the way I would go- reinforcement plate, then weld to FEL in line with the lift cylinders. Weld all the way around the hook and the plate. You may need to stop just prior to closure to let it cool off and vent any gas then finish closing the space. This will prevent any water from getting underneath that could cause freezing and/ rusting.
   / Seeking advice on welding hook to FEL bucket #7
   / Seeking advice on welding hook to FEL bucket #8
Do what this guy says. he's welded everything to everything. Just look at that weld quality. Wow, that weld could hold the Queen mary.
Disgusting isn't it?!
   / Seeking advice on welding hook to FEL bucket #9
One thing I know for sure is that my little Kioti's FEL is not going to bust it...:D
   / Seeking advice on welding hook to FEL bucket #10
Yup, as for the void space there's not going to be enough volume to blow out. Use the doubler plate as you said and go at it..Mike
Champion C80 B (A50322)
Champion C80 B...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2016 Ford Fusion SE (A50324)
2016 Ford Fusion...
