Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #4,141
Speaking of outside air intake dampers in fireplaces, I have that setup with glass doors in my new place and want to retrofit the fireplace with a modern insert and SS flue. The wood stove place in town said they don't make inserts with outside air (crawlspace air) intake. Google indicates they need to be custom fit which makes 100% sense. A link I did come across poo poo'd the advantages of outside air as combustion air. Any opinions?
It makes a lot of sense to me. Here's my thinking: I'm pretty sure that all of that flue gas, going out of the house through the stove & chimney has to be replaced by fresh air coming into the house from somewhere. Otherwise our ears would pop from the pressure drop and, after a spell, the whole house would implode. Most likely it's coming from the path of least resistance - everyone knows that air is a no good, lazy goldbrick. In our case, that slothful way is through our wall outlets, attic hatch, leaky old windows and exterior door jambs. So the house is suckin' in cold air, through all the rooms we're trying to keep warm, all the way down to the basement where the woodstove is breathing it in and huffing it out the chimney. It's not really noticeable once the fire settles into a slow burn, but when you start a fresh load and the draw is really strong you can feel the chill coming in, if you're near a door or window. It gets worse if someone turns the kitchen range or the bathroom vent fan on or runs a load in the clothes dryer. Turn on a vent fan and run a load in the dryer and you're bound to start smelling smoke drawn from the stove.
One of my projects for this winter is to finish running a 3" PVC fresh air line from the basement sill to the base of the chimney, a few feet from the air inlet to the stove. It'll have a gate valve in a convenient location, so I can throttle the flow or close it off completely when the stove's not burning. I'd rather have the stove breathing cold air, directly from outside and along a path of very low resistance, than to drag it all the way through the house, extracting warmth from the air that I just heated. I'm not 100% convinced it will it makes a noticeable difference, but I've pretty well talked myself into believing that it will, at least at our house.
-Jim
/ Tractors and wood! Show your pics #4,142
Fresh air is something I appreciate!
Hot and stale air is unhealthy.
I like a leaky, drafty house with a good wood stove. If I'm a bit chilly, I just move a bit closer to the stove! ;-)
/ Tractors and wood! Show your pics #4,143
I've got a stove hood( for the kitchen stove) that vents outside which creates a negative pressure inside the house. If you open the wood stove doors at the same time the vent is running the air path of least resistance becomes the chimney. It only took me once to figure that one out. It filled the whole house with smoke and set off the smoke detectors.
/ Tractors and wood! Show your pics #4,144
I tend to agree! I don't want to see light thru the cracks but fresh air is healthy. No doubt about that.
/ Tractors and wood! Show your pics #4,145
At the cabin one year the damper on the fireplace was left open and a raccoon got inside... what a mess... soot everywhere... walls, furniture, floors.
After that I made up a stainless cap and bolted it to the chimney...
/ Tractors and wood! Show your pics #4,146
Nothing would close up those leaks if the insert burned outside air. You'd get just as much fresh air as if it was 72 degrees outside. It seems that it would take a lot less wood to heat the house, less firewood cutting, less smoke, etc. etc.
/ Tractors and wood! Show your pics #4,147
I also have an outside air source for my fireplace. The fire needs air. Why use nice warm inside air for the fire and send it up the chimney and replace that warm inside air you lost with cold outside air thru cracks, vents, cracked open window, or down other flues. Bring in cold air directly to the fire and keep the warm air where it is. After all you are trying to heat the place up !
gg
/ Tractors and wood! Show your pics #4,149
Our new house is so tight (spray foam insulation, among other things) I would be afraid to run the fireplace without the outside air kit. As it is, even with the outside air damper all the way open, turning the range hood on high or turning on a couple bathroom exhaust fans at the same time will pull a whiff of smoke into the room now and then.
We mainly run with the fireplace doors open for the most radiant heat, but when running with the doors closed, the outside air kit is pretty much a requirement -- it becomes the only air intake at that point besides leaks around the doors. When running with doors closed, the currents of air coming from the air intake really swirl the flames into an impressive show. The air intake vents are a bunch of holes just behind the hinge line of each door, at the side of the fireplace, and they seem to result in "jets" of air that really stoke the fire up.
/ Tractors and wood! Show your pics #4,150
While burning my wood stove I usually have a door cracked open or the storm doors open for fresh air. I do it for two reasons; first is fresh air for the fire and second it gets to hot in the house if I have everything closed up tight. I do wish I had a cold air intake for just the wood stove. It just makes good sense.
/ Tractors and wood! Show your pics #4,151
I have been using outside air for my wood boiler for years. Very happy with the results. Here are some photos of a simple way
to access, direct, and control the air flow to the area of combustion.
-First photo shows the outside air source at the lower primary air intake, and also in the upper secondary air intake.
-Second photo shows the basement window with a round hole cut in it and a 6" pvc drain pipe accessing the outside air.
-Third photo shows the drain pipe run through the joist area. Above the boiler the pipe is capped and 2 smaller pvc pipes
run down to their respective air intake areas.
No fan needed. Outside air is always running through the pvc pipes to the stove with higher concentrations of oxygen for better
combustion. The sliding gate near the window allows for full control of the outside air flow, and also acts as a shut off.
/ Tractors and wood! Show your pics #4,152
That's good jodebg.
For my wood furnace in the cellar I use the near-by floor drain for outside air. It runs under the floor then under ground about 150 feet to daylight on a bank. I put a tee and a stand pipe out there to keep it above the snow. It can be -30F outside and the air feeding the furnace is never less than 45 degrees.
gg
/ Tractors and wood! Show your pics #4,153
Very smart... another TBN tip.
/ Tractors and wood! Show your pics #4,154
I have an outside air intake for the wood stove but I crack a door and leave the stove door open while starting. After everything is going, I have a heat recovery forced ventilation system to bring some fresh air into the house.
/ Tractors and wood! Show your pics #4,155
Hi Gordon-
That's a great idea!
That's good jodebg.
gg
/ Tractors and wood! Show your pics #4,156
jodebg - you're install looks remarkably similar to what I planned to do, except I was going to run mine out of an unused bathroom vent fan outlet. Nice home brew gate valve, too. But now I've got to make one little change ...
That's good jodebg.
gg
That's a great idea. I've been planning on digging a trench and laying a 4" drain line from our basement sump out to a downhill, daylight outlet above a drainage swale. Total run will be 130 feet and drop about 6. This should ensure that the basement won't flood if the sump pump fails. Again. Should also take a bite out of the electric bill and make for better peace and quiet during rainy periods. A few years ago that pump would run for 3 minutes, rest for 2, then back on for 3, etc, 24/7 for 3 or 4 months. When I looked at the electric bill the spike up & down in usage synched perfectly with the unremitting rain we had. We've toasted 2 pumps in 8 years. I was scared to leave the house for more than a day at a time, since our electric service has been out for several days, more than once, in that same 8 years.
But I will definitely crib your idea and add a FAWGAIR (Fresh Air With Geothermal Augmentation Induction System) riser to the drain.
-Jim
/ Tractors and wood! Show your pics #4,157
Don't forget to install some type of metal screen or hardware mesh to prevent rodents from making that 3" PVC their super-highway for easy access into your house.
/ Tractors and wood! Show your pics #4,158
Yeah, I was going suggest that too :D
/ Tractors and wood! Show your pics #4,159
After the third tree frog showed up in the wife's toilet.... let's just say I had to make it a priority to put a mesh screen cap on mine for the toilets.
It was loudly and very explicitly explained that task was now moved to top of existing project schedule to take precedence over all Tractor and beer drinking activities!
/ Tractors and wood! Show your pics #4,160
That's funny!
Cat CB24B (A60462)
Cat CB24B (A60462)
FENCE PANELS (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
