Cheap battery cover...
/ Cheap battery cover... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
I had some left over Wally 1/4" sign foam board and made a quick cover/snow deflector for the battery. Whilst snow blowing the lake effect stuff, my battery was getting blasted with snow sucked into AC/hyd/intercooler/coolant radiators. Was finding icy blob on top of the battery at the end of running the blower. To keep this from possibly effecting the posts and connectors, I just covered it with some left over foam board from the radiator cover I had made earlier [ 12" center hole ]. Anywhilst, we will see if this keeps the top of the battery dryer. Getting a day off from the everyday road clearing duties today... :)
/ Cheap battery cover... #2
Reduce, Reuse, Recycle. I love all of the ingenuity here on TBN. I just picked up my Meteor 60-inch and I can see these same symptoms happening with the reverse flow (op station to front) cooling fan system on my MF GC1720. I may have to borrow this idea.
/ Cheap battery cover... #3
That looks good. Real nice. As long as it's not gas tight so hydrogen has a way to vent, you're good to go. That is unless you've changed the battery to an AGM type.
/ Cheap battery cover... #4
Nice job, Jerry, but I think I'd like to be able to see the terminals so I can see how badly they're corroding.
I will take it off in the Spring, if I am not too senile to remember... along with the cover I put on the radiator... AND, if I am still kicking... [[ :) ]]
/ Cheap battery cover... #6
Just put a note to yourself on your can of wax. That way you'll be sure to see it.
:) :) :) [ probably be better to put note on my diesel cans... been burning a lot moving snow... ]
/ Cheap battery cover... #8
I kinda figured you didn't wax until the weather improved a little so it seemed the ideal place.
