Added Grapple to bucket
/ Added Grapple to bucket #1
setxjeff
Newton County, Texas
1951 IH cub, International 254 and 1538 Mahindra Towable Backhoe
Added grapple and tooth bar to bucket. Love it for small clean-up, still put full size grapple on for brush piles.
Grapple from Green Machine The Thumb They call it the Thumb. Tooth bar from titan implements. IMG_0737.JPGIMG_0738.JPG
/ Added Grapple to bucket #2
Very handy and useful set up that you have added :thumbsup: I bet you find it way more capable than you originally thought and will enjoy the added versatility off having both a bucket and a grapple.
gg
/ Added Grapple to bucket #3
I have the same exact set-up for my L4240 Kubota;best investment for the tractor ever.
/ Added Grapple to bucket #4
I have one on my little GC1720 and love it!
/ Added Grapple to bucket #5
Here is the one I put together for around $500.00 bucket and all.
/ Added Grapple to bucket #6
Looks great. I have one of the Green Machine The Thumb on my Kubota bucket. It works great and is very handy.
/ Added Grapple to bucket #7
Thanks for posting this setxjeff!
I've lusted after a grapple or a thumb since the day I bought my tractor over a year and a half ago. Just couldn't bring myself to spend the kind of money a full grapple costs, plus didn't like the idea of having it permanently attached to the bucket.
After a couple of emails to Green Machine, I ordered the 24" model today and plan to build mounts for both my bucket and my forks. The fork frame will require some modification but the plan is to arrange things so it will bolt to either device in a few minutes.
I expect it'll get used most on the forks for handling firewood logs, but it will be nice to be able to swap it to the bucket if needed or just take it off completely.
As a cost-savings measure, I won't be adding a third function to the loader joystick (Holy COW they're expensive!) but will run hoses from the rear remote and use the separate valve in the cab.
I'll document the process and post pictures. The thumb was $467 including shipping, I should be able to get this done for under $700 including steel and hoses.
/ Added Grapple to bucket #8
That's how I did mine to use on forks or bucket.
/ Added Grapple to bucket #9
The thumb grapple seems relatively inexpensive as an alternative to purchasing a full out grapple. I like it. And it seems like it would be able to grab brush and or rocks as well, which is what I would primarily be using a grapple for. Much cheaper than the $1990 grapple itself option.
/ Added Grapple to bucket #10
I got an email from UPS today saying it's on the truck for delivery tomorrow.
If I can get to the steel place, I'll start on the project this weekend. Looks like it'll be too nasty to do anything else anyway.
/ Added Grapple to bucket #11
Here is how I did mine.Tacked the nuts to the bottom of the angle for easy
removal.I had to "tilt" the angle a little so the Thumb would close on the bottom
of my bucket.I can pick up a one inch thick rock or a huge pile of brush.
The tooth-bar is a worth while addition also.
/ Added Grapple to bucket #12
I would sure like a grapple but I keep thinking I need more reach with the grapple as my biggest use for it would be for brush. Am I being too picky?
/ Added Grapple to bucket #13
Do you have pallet forks that you could add a Thumb to?
/ Added Grapple to bucket #14
I wish I had taken pictures when moving brush piles;I could grab a huge pile with my set-up.Loaded logs on the a portable saw mill with great ease and control.Only limit with this set-up it doesn't open as wide as a full grapple;something like a large round bale would be difficult.
/ Added Grapple to bucket #15
I will be getting pallet forks as I have a lot of use for them on my Versatile. I wonder about the pallet forks for brush though as I have a lot of pond edge meaning willows and dead willows drop a lot of twigs which was why I was thinking grapple on a bucket.
The nice part of a grapple on pallet forks would be for handling more than one log as the tractor is big enough to handle more than one log.
/ Added Grapple to bucket #16
Got a good start on installing the grapple mounts. Below Zero and 20 knots of wind and working in an unheated garage...what fun!
Details and more pix here:Shopbuilt Forum
/ Added Grapple to bucket #17
xfaxman you just have decide how the brush is.. if its tree tops and connected just get a bit and the rest comes along for the ride..20150613_101511.jpg
/ Added Grapple to bucket #18
Yep, then I go back and pick up what fell off along the way to the brush pile. :D
/ Added Grapple to bucket #20
Some details to finish up. I didn't allow for bucket curl when I thought about hoses from the loader to the thumb cylinder so I need to let things flop until I can get longer hoses. Then I'll secure the hoses from the rear remote to the loader cross-member with a bracket and just have the hoses from there to the thumb flexing.
Also should have ordered the 28" instead of the 24" thumb, but I don't think that will be much of a problem, and if it is, I can rig an extension.
Full story here.
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
Brute Pressure Washer (A65640)
Brute Pressure...
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
