Pto install
/ Pto install
When I pull the shaft out, I have to give it a sharp jerk to get it free.
/ Pto install
When removing the shaft, a sharp jerk is required to free it.
/ Pto install #13
Ok so if I'm reading correctly how everything all goes together then part 10 engages part 3 which is bolted to part 2. Part 2 moves part 12 back and forth to engage the pto. If I'm correct then it looks like part 12 has two groves in it. Could part 2 be in the wrong grove? Could there be a burr or something on the splines of the pto shaft that slide into part 12?
Edited to add: I looked on eBay and there are several good deals on factory Ford service manuals. Several combinations of owners, parts and service manuals. If you are going to continue to do your own service a factory manual is highly recommended. I&T manuals are ok but they never go into the detail that a factory service manual does. Search "ford 801 manual". I tried to find a pdf of a manual but the prices for paper ones are very reasonable. Just a suggestion.
I just looked through eBay some more and the first pdf I came to for $28.95 has everything you need. Ford 61 81 Tractor SERVICE, PARTS Catalog, OWNERS Manual -6- Manuals 1953-1964 | eBay
/ Pto install
After about a zillion attempts I put the pto In neutral, held the shifter and gently pecked the end of the shaft, it went in. Thanks for your help and heads up on a Manuel.
/ Pto install
I was nervous about the hammer use but I took off the side plate, felt the inside splines and made sure the pto shaft was inserted propely.
4022CFL (A59228)
4022CFL (A59228)
2022 Kubota M5-111 (A60462)
2022 Kubota M5-111...
King Kutter II Tiller for sale.
King Kutter II...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
2007 International 4300 Altec DM47 TR 47ft Insulated Digger Derrick Truck (A60352)
2007 International...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
