   / Harbor Freight Tools that don't suck #6,591
Gotta figure it's worse for the other sex.
   / Harbor Freight Tools that don't suck #6,592
Particularly if she trades sides of the bed the next night.
I thought the correct modern spelling was "hafta"
   / Harbor Freight Tools that don't suck #6,594
Silver And Deming Drill Bit Set 9/16 to 1", with 1/2" shanks, $35. After 25% coupon = $26.25. Any good?
I've got a set like that (mine goes up to 1 1/4") and have only used them but only to chase and clear out existing drilled holes or expand an already drilled hole by a small amount like 1/16th or so. I used a drill press with cutting oil and for my purpose they worked fine. They stayed sharp and worked well with no burring of the drill edge. I went slow speed and they cut clean.
That's all I have done with them because I lack the confidence to try to drill a new hole. They look and feel like they would do it but someone else will have to answer that part. Hope my comments help.
   / Harbor Freight Tools that don't suck #6,595
Need a coupon?
   / Harbor Freight Tools that don't suck #6,596
I also have a set of them. They are good but you have to be sure to securely clamp whatever you are drilling with them. Don't attempt to drill with a hand drill because if the bit catches it will twist your arm off. Same goes for using a drill press. Never try holding what you are drilling. If the bit catches it will rip it right out of your hands. Been there, done that.
   / Harbor Freight Tools that don't suck #6,597
25offFF_print.jpg Got this 25% off coupons this morning and it said it can be shared
   / Harbor Freight Tools that don't suck #6,598
My experience has been the same. I have the same set, I use it in the drillpress and have been happy with it. I only have 10-20 holes drilled with it though, but I always use cutting oil (CRC foaming cutting oil purchased from HF).
Aaron Z
   / Harbor Freight Tools that don't suck #6,599
You really want to step drill with these things, that 1/2 shank isn't enough to take the torque of pushing a bigger drill thru. I'd drill with a 1/8, then a 1/4, then a 1/2, then to a 1 inch or more. IMHO, you need clearance for the web on the bigger drills. I've got that set, it works fine, but my little drill press isn't up to putting a big hole in a hunk of steel either....:)
And coolant helps a lot!
10 Ft Fork extensions (A50322)
10 Ft Fork...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A51219)
2021 FREIGHTLINER...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
