Stump Removal
   / Stump Removal #1
kcflhrc
Kansas
2013 John Deere 3032E
Any DIY tricks for stump removal. I'm in no hurry to get rid of it. I had thought of drilling several holes in it and filling the holes with either diesel fuel or charcoal lighter and letting it burn to start. It's out in my pasture so it's not really hurting anything.
   / Stump Removal #2
Get an old rear tractor rim and put over top of it and burn your brush in it until gone. I don't recommend and additive fluids but if you were to spill something in the rim it wouldn't hurt :)
   / Stump Removal
I have lots of brush to burn so this is probably what I will do. Eventually it will burn away.
   / Stump Removal #4
Try some Spectracide (potassium nitrate) available at Amazon or Home Depot.
   / Stump Removal
I saw that on Amazon last night, maybe worth a try. I do like building fires though.
   / Stump Removal #7
I have about a dozen to remove. Can't afford a contractor. Tried burning but the stumps are too hard and fire doesn't do much. I got rid of some by digging around them and chainsawing low and then covering the cut off stump but that is too hard on my body too. I will look up that potassium nitrate to see if it will benefit my case.
Found this
How to Remove a Tree Stump Painlessly | The Family Handyman
   / Stump Removal #9
Yeah, just drill big holes down into the stump and fill them with ammonium nitrate fertilizer. After it soaks in a while, build a fire on top of it. The ammonium nitrate is an oxidizer and will help the stump burn.
   / Stump Removal #10
Or drill a deep hole and put some tannerite in it. Probably would make it disappear.
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
Pallet Fees (A50774)
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2019 POLARIS XP1000 RANGER (A51222)
2019 POLARIS...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
