Hitching bush hog to D2 Cat
/ Hitching bush hog to D2 Cat #1
msjanket
My D2 Cat has a PTO and I'd like to hitch it up and use it in some hilly ground that has some brush on it. Assuming the PTO shaft fits well for length, what kind of bracing is needed to stabilize the attachment, in lieu of having a 3 pt hitch, which I don't have?
Has anybody hitched a hog to a D2 and used it effectively?
/ Hitching bush hog to D2 Cat #3
Pull behind cutter?
/ Hitching bush hog to D2 Cat #4
Buy or build a 3 point lift: Three Point Hitch Kits
Pictures: 3 point kit - Google Search
/ Hitching bush hog to D2 Cat #5
Why go through the trouble to buy/build a 3 point, when you can just buy a pull behind rotary cutter!
My question is, what's the rpm of the CAT's pto? Does it "reverse" when you put the trans in reverse?? Does it have an "over run" clutch built in?
SR
/ Hitching bush hog to D2 Cat #6
Pull type bush hog would be the best. Be sure and get a bush hog, not a finishing mower.
/ Hitching bush hog to D2 Cat #7
SR
Because he already has the 3 point brush hog.
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2019 Caterpillar 289D (A64126)
2019 Caterpillar...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
