L3301 HST stationary PTO mode
/ L3301 HST stationary PTO mode #1
ericm979
Super Member
Southern Oregon
Branson 3725H Deere 5105
I was at the tractor dealer today checking out small Ls and large Bs. The salesman and I could not get the L3301's PTO to stay running when I stood up.
The web site says it's got stationary PTO mode. How is it enabled?
It's weird that the B3350's throttle lever works backwards from the one on the L and my B7100.
Eric
/ L3301 HST stationary PTO mode #2
Lift the seat UP as you get off, you have a second or two... Tilt it up and on the steering wheel.
/ L3301 HST stationary PTO mode #3
I just flip the seat forward before engaging the PTO. That is how they intend you to get it to run the PTO without the operator presence switch kicking in.
/ L3301 HST stationary PTO mode #4
I zip tied down my operator presence sensor switch so I could stand & see the end of my pallet forks. Would work for this as well if proper flipping of the seat is to much of a pain.
/ L3301 HST stationary PTO mode #5
According to the manual;gear selector in neutral,brake on,engage PTO and tilt seat forward or if that doesn't work a 50# sack on the seat!
/ L3301 HST stationary PTO mode #8
I don't know if the tractor has to be in N to run the PTO in stationary -- don't think there's a switch to even detect that -- but it's sure a good idea. I always slide the gear selector into N when I run my wood chipper. One less thing that can go wrong.
/ L3301 HST stationary PTO mode #9
My HST has a neutral position?
It does but I've never put my HST into Neutral for chipping. I do put the brake on pretty much any time I get off the tractor... it has a habit of rolling if I don't.
2017 Hino 268 Cab and Chassis Truck (A59230)
2017 Hino 268 Cab...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2011 Nissan Rogue SUV (A59231)
2011 Nissan Rogue...
2016 Kenworth T680 20 Yard Tri Axle Dump Truck (A59230)
2016 Kenworth T680...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
