Snow Going through second stage bolts
/ Going through second stage bolts #1
jrogers
Anchorage, AK
Kubota 2630HSD
On my first plow of the year I went through a couple of second stage bolts on my Kubota snowblower. I thought it was from the wet snow, but today we had 6 inches of dry snow, and I went through 3 more. I did not see that I was hitting anything, it seemed like if I even loaded it up much they broke. Any suggestions on how to deal with this, short of putting a non-shear bolt in? Can this be a symptom of something else wrong with the blower? Is it better to torque the shear bolts really tight, or just snug for maximum torque before breaking? Any help is appreciated.
/ Going through second stage bolts #2
When I had a snowblower the first time I would use it, each winter, would always "cost" a couple shear bolts. It was always from rocks getting jammed in the fan. I found that being in my open station tractor - I would always hear whatever caused the bolt to shear as it hit the fan.
Something on your blower is wrong OR you may need a tougher shear bolt. I'm not quite sure what you mean by "second stage shear bolt". Explain
BEFORE you go to a tougher shear bolt - drop into your Kubota dealer and see if he can figure it out.
I always used grade 2 - regular old hardware store bolts on my blower. I always tightened them down pretty good - so there was no possible slop at the bolt location.
BTW - I lived in Anchorage - - 1965 thru 1982.
/ Going through second stage bolts #3
I had a problem with bolts shearing on my 3-pt hitch blower 2 years back during a heavy snow season. What I found was the pto shaft wasn't freely sliding in and out. Check yours. If it's not sliding freely, get some spray lube in there like Fluid Film. I was using white lithium spray grease and it gummed up the action.
/ Going through second stage bolts #4
By second stage do you mean the shear bolt protecting the auger which feeds the snow to the fan?
Are you using SAE bolts ( American thread) which fit the hole or the possibly correct metric bolts. A small increase in the diameter can increase the strength significantly.
Could you post a picture of the bolt you are using. One photo of the head of the bolt and another shot of the side of the whole bolt.
Dave M7040
/ Going through second stage bolts #5
All the questions about "Which shear bolt do you mean?" are good ones. One thing I have found with shear bolts in other applications (tillers, small bush hogs, etc.) is that the bolt must exactly fit the hole. Almost force fit. English instead of metric is bad, etc. If there is the slightest bit of slop in the hole that the shear bolt goes in it will shear in very little time.
/ Going through second stage bolts #6
Run wot and that should help. Slower rpms can put stress on the bolts
When I said second stage, I meant not the auger but the fan (the vertical section). I rarely shear the auger bolts. The bolts I have been getting are from the Kubota dealer, so I am assuming that they are giving me the right thing. We have had some warming and cooling, so the driveway has had some 'traction sand' put on it, which has some coarser sized pebbles in it that may be causing the issue, maybe a 1/4" in diameter. Thanks for the advice on running the blower at full speed as well as torquing the bolts tight, those are both things that I have been wondering about. I took the time today and greased all of the fittings on the blower. It probably won't help but certainly won't hurt.
So do you think the traction sand could be the issue, and do you think a finer sand would cause less issues?
Thanks for all of the replys.
/ Going through second stage bolts #8
1/4 inch is .250" and 6mm is .236"
/ Going through second stage bolts #9
You should be able to blow lawn sod through your blower so sand is not going to be the problem. Typically shear bolts break when you "find" that concrete block you forgot to move buried in the snow and you try and blow it.
How about a model number of your blower and is it front or rear mounted.
If rear mounted, is your pto multiple speeds and what speed are you running it at?
The rear mount blowers I have experience with have a total of two shear bolts one on the pto shaft which protects everything but especially the fan and a second on the auger. Your description makes me think your blower is front mounted. Is it?
Do you have a manual for your blower and if so what does it state about shear bolt specifications?
Dealer parts guys are not infallible when it comes to giving you the correct shear bolt for the blower you have. Did he look up a part number or just grab one from a bin? do you have an invoice with a part number on it?
This has to be a problem with a simple solution.
Dave M7040
/ Going through second stage bolts #10
I have been running a 5ft Agro-Trend 3pt mounted snowblower for 20 years. I don't use it many times per year but when I do it is usually rough and a workout in heavy snow. In mountains of WV. I can recall throwing large gravel accidentally for long distances, picking up chunks of ice that went through the blower sounding like a bush hog that just hit a 2x4. I drive it with a 24hp Kubota B2150. I have never replaced the original shear bolt. Never a problem (yet...) So I have to wonder what on earth is wrong with your rig. I've never owned a Kubota brand snowblower but I heard they are made in Quebec for Kubota by a company with a pretty solid reputation. What you describe is just not right -- something is haywire. The shear bolt must fit very snug/tight and cannot have any play in the hole. Go read the manual and don't count on the dealer to give you the right shear bolt. Does the rotor turn fairly easily by hand (when the tractor is shut off) and not seem to be catching on something or wobbling ? By the way, shear bolts are normally intended to break when excessive loads occur and are NOT normally high grade bolts. Plain old grade 2 usually. I would not go putting in a super strong bolt until I figure out what the problem is. The manual should tell you what grade bolt to use. Checked the lube in the gearbox ? ... Let us know what you find !
/ Going through second stage bolts #11
My front mount blower has different shear bolts for the impeller vs the auger. My old dealer said there isn't much difference as the are the same size. I continued to shear pins about 6 a season. My current dealer said kubota has 2 part numbers for a reason. I have not sheared any since. Same driveway and same blower.
/ Going through second stage bolts #12
It doesn't take much gravel to shear a pin in my experience, but then again, the last time I ran a snow blower was about 25 years ago back when I lived in New England. Had gravel driveways in both CT and VT, and in both cases small pieces of gravel could jam an auger or impeller enough to shear a pin. I think it's a bit of a random thing, since I also saw plenty of gravel come out the chute that did not result in a sheared pin. Just depends on how much clearance there is around the rotating parts to see if it can possibly happen.
I would suggest getting the parts diagram for the blower and make sure you have the right pins for both auger and impeller. I do remember them being different on the machines I ran, most likely because there were different diameters and speeds, so obviously the torque that can shear the auger is different than what could shear the impeller. It would be rare I'd think for both parts to use the same exact pins.
/ Going through second stage bolts #13
And you can bet money the 2 shear bolts ARE supposed to be different sizes -- close but not the same. One was loose in the hole and shearing all the time. Your current dealer is the one to listen to.
The snowblower is a 2782. Attached are photos of it as well as the bolts that I got from the dealer. I filled the gearbox as suggested. It was maybe 25% down. The fan spins really freely when there is no shear bolt in, and the shear bolt fits really tight. Let me know if you see anything wrong. 20161204_091910.jpg20161204_092028.jpg
/ Going through second stage bolts #15
Hmm...1/4" grade 8 shear bolts. interesting
/ Going through second stage bolts #16
You can cause shear bolts to break by installing them too tight which pre-stresses them. Engaging the fan at high RPM also puts extra stress on them. A lot of two stage blowers which have the two shear pins, one on the fan drive and one for the auger, all the stress for driving both is initially going thru the smaller fan shear bolt. You should also check for something binding in the auger area in this case [ chain/gearbox/auger itself/etc] .
/ Going through second stage bolts #18
I always like to use graded bolts for shear pins on my blower.
Too soft and they fold or tear rather than shear while graded make a nice clean cut and drive out easily.
The softer ones actually need a drift punch to extract plus they just don't last.
I have used graded for about 7 years with no damage at all to augers of fan plus I also run my blower at 700 RPM rather than the lower 500 as I have 3 speed PTO, the 500 just will not throw snow far enough while the 7xx is just nice.
Note however my blower is 3 bladed fan type and as such not best performer but it is what I have.
Whenever I shear a fan shear bolt it generally is from a fist sized stone getting jammed in a fan blade usually from city plow having stones in the sander and ending up in my drive entrance.
/ Going through second stage bolts #19
Those look like the correct shear bolts for the blower.
I also have the B2782 blower.
The dealer gave me a bag of each at delivery,1/4 grade 8 for the fan and 5/16 grade 5 with a groove for the auger.
They're a Kubota/New Holland dealer so I got the NH part numbers.
Blowers for both are from RAD in Quebec.
Good Luck!
/ Going through second stage bolts #20
The only time I sheared a bolt (auger) was when I hit a concrete block. I have never sheared the other bolt.
Chevrolet Tailgate Sign (A64127)
Chevrolet Tailgate...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2017 John Deere 6110M (A64126)
2017 John Deere...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
