Things I've made
/ Things I've made #1
Shaneard
Southern Virginia
Ford 4630, Two IH 140's, John Deere A
I work in a machine shop and have access to mills, lathes etc. and my boss let's me do what I want. I know, I'm so blessed! I have 3 welders at home, a Hypertherm plasma cutter, Ellis 1800 band saw and hardly ever use any of it anymore since my boss lets me do it at work while the milling machine I run is running (3 axis). Here are a few projects I have made in the past. First is a gooseneck hitch.
/ Things I've made
Second is a reese hitch. Had it powdercoat painted. If your wondering what the offset hitch to the left is for it's for pulling the haybine with offset tongue to give more room on the road. I also made something to go in it.
/ Things I've made
The offset hitch also houses my deer skinning rack. It rotates 360ー & I made it offset so I can let tailgate down and also pull trailer with it in hitch. Made all the pins & pulleys out of stainless. Also made an adjustable stainless gambrel.
/ Things I've made
Made some wheel to wheel steps for the truck, had them powdercoated as well.
/ Things I've made
Made an aluminum plug for the fuel filter on the truck where the plastic one was.
/ Things I've made
Hitch for the mower & a basket above engine for 15 gallon sprayer.
/ Things I've made
Hitch for front of Sonoma. Powdercoated as well.
/ Things I've made
Hitch for three point.
/ Things I've made #9
I had a friend with a machine/welding/sheetmetal shop. He gave me free access to his facility and it sure came in handy when I did the suspension and axle swap on my truck. All I had to do was pop over when I needed to make some sort of doodad. Most of the time I could dig the material out of his scrap bin. I did buy him a really nice Miller plasma cutter as thanks. I sent a lot of business his way too.
Sadly when all the silicon stuff went off shore he went out of business. Now there is nothing in a valley that used to be full of machine and tool and die shops. The few machine shops left really struggle to hang on.
/ Things I've made #11
Nice work. Sounds like you work for good people. That's hard to find these days. Thanks for sharing.
/ Things I've made #12
Man that's some nice work. Makes my shoddy welding sure enough look bad. :)
/ Things I've made #13
I Dunno, Looks aweful flimsy. The mower I mean not the hitch
/ Things I've made #15
In my experience, the guys that did the best government work were the guys the supervisors could count on to do the best work for the company.
Your boss is a wise man.
/ Things I've made #16
Nice job Shaneard.........The pride in your work really shows:thumbsup:
/ Things I've made
Made a rim lock for an Allis Chalmers motor grader this morning. A friend is restoring one and he can't find one anywhere. He wanted me to convert another someone gave him but it wasn't tall enough and would have been more work than making one from scratch.
/ Things I've made
Thank you! I do work for good people and you're welcome!
2006 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2006 JLG 600S...
2014 KOMATSU D61PXI-23 CRAWLER DOZER (A62129)
2014 KOMATSU...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
500BBL WHEELED...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
