Even Cheaper Backup Camera
/ Even Cheaper Backup Camera #1
KennyG
Super Member
SW Michigan
John Deere 2320
I was looking at the $50 camera thread and thought it would work well for me. I added mirrors to my soft cab for my 3 point snowblower, but it's not ideal. I found a $30 camera on Amazon and installed it and it seems to work well. Just a 4.3" monitor though.
Amazon.com: Backup Camera and Monitor Kit, Chuanganzhuo License Plate CMOS Wide Angle Back up Camera With 7 LED Night Vision+ 4.3 TFT LCD Monitor: Car Electronics
I need to clean up my wiring a little, but I mostly used the wire looms from my LED light installation and I had an extra 12v switch from that mod. The hardest part was the camera and monitor power wires. Why do they have to use 22 or 24 gauge wire? It's pretty hard to strip and splice.
/ Even Cheaper Backup Camera #3
Not bad. I got one from rural king. Peak brand ( the antifreeze people ). was a kit on sale for 49$, regularly 80$. Works.. not super high quality.... but works..
/ Even Cheaper Backup Camera #4
I remember cursing that thin wire when I installed my camera system too. It's really hard to work with.
/ Even Cheaper Backup Camera #5
I've worked with 24ga solid and stranded for years. it's a pita and takes practice.
/ Even Cheaper Backup Camera #7
I never had much trouble with it. I've used a lot of 30 gauge wire wrap wire too. It's all easy if you have the proper gauge strippers.
/ Even Cheaper Backup Camera #8
We work with it ok, but the other 99% of the population think its magic.. Just like the rest of electronics ;)
/ Even Cheaper Backup Camera #9
I'd forgotten about those telephone splices. I used those a lot when I was doing telephone cable installation, but that was almost 50 years ago. My hassle was splicing the small wires to the 14 gauge SAE disconnects I'm using everywhere else in my aux wiring. I don't know of a splice that's made for that difference in wire size. But I got it cobbled up and working.
/ Even Cheaper Backup Camera #11
The problem I has was the thin wire used by the camera/monitor was obviously very cheap, with poor quality insulation. There were a few spots where I needed to solder that to some Southwire cable I bought to extend the harness through my loader frame. The Southwire stuff stripped without issues, but the cheap wire from the camera was very difficult to strip without causing damage to the conductors. The insulation was almost rubbery/stretchy/gummy.
/ Even Cheaper Backup Camera #12
Watch it for cracking as it ages. I've seen some pretty poor 'rubber' insulation from china items.
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
1978 Ford L8000 Fuel and Lube Truck (A61165)
1978 Ford L8000...
(2) 23.1-26/18-26 TRACTOR TIRES (A62131)
(2) 23.1-26/18-26...
2002 Freightliner FS65 Chassis Bus, VIN # 4UZAAXAK52CJ75416 (A61165)
2002 Freightliner...
(3) 31'X52' BULL FLEX HAY TARPS (A62131)
(3) 31'X52' BULL...
Lifts (A61567)
Lifts (A61567)
