Fuel winterizer
/ Fuel winterizer #1
ole dummy
Member
Decatur, Al
2014 3560 Kubota Grande L
What kind of fuel winterizer do you use if any? I have never used any in my tractors but am thinking about it. I don't use my tractor in the winterso it just sits in the garage. Do I need to to add winterizer to the fuel? Your thoughts.
/ Fuel winterizer #2
Depending on where you live algae growth and condensation are probably your two biggest concerns. If you aren't going to empty the tank you might want to fill it up and add something recommended by your local dealership. They should know what kind of issues are common in your area.
/ Fuel winterizer #3
Because I don't use a lot of diesel, I run Power Service Diesel Treatment year round. It supposedly gives added power in addition to the anti-jellying factor. At any rate, I never have to worry about when and if they add it at the local pumps for winter.
/ Fuel winterizer
Thanks for the info, I will talk to my dealer about this.
/ Fuel winterizer #5
I've used Power Service in the white bottle for several years...all year long. For me, it's for the added upper cylinder lubricity. The anti-jell aspect is just an added benefit.
When we first moved to Vermont during the winter of 2012/2013, my tractor sat outside for the duration (no garage at the rental house we lived in). The tractor, a Deere 4400, had no problem starting when we had to clear snow. Now, this tractor, as well as my current one (4520) had a block heater and that helps a lot.
/ Fuel winterizer
Roy, I saw the Power Service at Auto Zone yesterday. How much do you use per gallon of fuel?
/ Fuel winterizer #9
I've been using PS for many years. I buy the 80 oz. bottles and dump the whole thing (as indicated on the bottle) into a 250 gallon tank. (actually 275 gallon but I don't fill it).
That works out to a little over 3 oz. per gallon. A few here use the glug method and put one or two glugs per gallon. Being down south your temps probably don't stay as cold like ours do so you may be able to use less per gallon.
I buy fuel in bulk but use that tank for my tractor, salamander heater, and 80K BTU garage furnace.
/ Fuel winterizer #11
A glug is 2.550 OZ so I use 4 glugs per 5 gallon jug.
/ Fuel winterizer #13
That is way way more than I use for a 5 gallon container. Maybe one glug if even that.
Sorry it was 4 glugs per fill which is 12 gallons.:ashamed:
/ Fuel winterizer #14
I'm gonna say if your using straight dino diesel from a reputable station no worries.
Now if it is biodiesel treat it or drain it.
/ Fuel winterizer #16
PS white bottle for me as well
/ Fuel winterizer #17
I bought winterized fuel in bulk this year and also poured in 64oz of Amsoil Injector Cleaner.
I was getting my 275gal tank filled at the fall timeframe and they asked me if I wanted normal or winterized. I went with winterized this year.
So far its been working out great.
/ Fuel winterizer #18
Half and half #1and #2 diesel fuel mix, PS white bottle, Goldenrod filter and water block cartridges on an HMC 30 gal caddy.
/ Fuel winterizer #20
If your tractor is sitting over in Decatur (only about 10 miles further north from where I sit as I write) it will probably only experience AVERAGE winter lows about 30 degrees F.
I don't know how much they winterize fuel around here but I've been here most winters since 2011 and have not worried about gelling. Not like Northern Vermont where I've had tanks of diesel turn to slush.
In your case I'd only worry about a biocide and top the tank off to prevent condensation.
And run it in the winter!! Heck a warm sunny winter day in Decatur is almost like a cold summer day in Vermont.
It's almost winter here and it's supposed to hit 74 degrees Wednesday.
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
207273 (A52708)
207273 (A52708)
Mini rock grapples (A61567)
Mini rock grapples...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A63569)
2019 GALYEAN...
2013 John Deere 825i Gator (A64047)
2013 John Deere...
