Burying a generator vault into a bank
   / Burying a generator vault into a bank #61
That's unbelievable! What if the rope were to break or the wooden handle rots off? You'd be royally screwed! That's a technology trap if I ever heard of one!
   / Burying a generator vault into a bank #62
I guess you would get another 50 cent length of rope and whittle a handle...
It was the standard for decades prior to recoil starters.
   / Burying a generator vault into a bank #63
First he'd have to walk the country roads looking for bottles to cash in for the deposit money to pay for the rope.... got any yucca plants? He could make his own rope. :)
   / Burying a generator vault into a bank #64
Yup. Am I the only one feeling incredibly OLD here??
Terry
   / Burying a generator vault into a bank #65
I wonder if that applies to the Canadian Code.
It's common knowledge that free electrons in Canada act the same as all free electrons.
   / Burying a generator vault into a bank #66
Haha I was thinking the same!
Also had a little crisis about the air compressor too. But the reality is I never use air tools. And the compressor runs a little while & shuts off (not like a generator). However if I HAD some tubing in my possession this morning, it would go in the trench!! Gonna cover it up by noon today. (snow tonite!!
What I have is Romex 10-2 & 12-2. My 12v pair is stranded THHN 10ga. For signal all I have is telephone cable 24ga. Why THHN ? (Thermoplastic High Heat Nylon). I'm doing my best to seal it but its like a level bucket. Seems like it could fill with water and remain full forever. I've been more worried about water than heat. (THWN Thermoplastic Heat Water resistant Nylon). Any ideas how to drain a level conduit with up-ends?
THHN will hold up to moisture quite well Romex will not. Next if you are running full power from the genset you should be using #8 or #6 sized wire. I would use #14 THHN for the low voltage wiring for the start/stop circuit. For the led lighting why not run it off the genset battery? If all else fails a good flashlight would be better for trouble shooting problems in the dark, you can aim it where needed.
If it were my project I would wait for the next trip and have the right materials on hand.
   / Burying a generator vault into a bank #67
I run Air line everywhere. Makes for a nice reservoir of air. Recently I used 3/4 or 1" 200 PSI tubing, got off craigs list.
Do those BTU numbers account for much of the heat going out in the exhaust?
The exhaust gases are about half of the total heat loss calculation and are included. In this case the exhaust is not leaving the box on its own tailpipe.
I have a bank of 12v batteries in my shop. Prob better if the lighting is not related to the generator. Tomorrow it snows, and Turkey-day forecast is for 8 inches more. Today is the day to get this done or it's all winter with an extension cord under the snow, and the door held open by the cord. NOT this winter!
I think it will be fine - most folks just run the dang thing outside their shop door and listen to it. :D Neighbors too. :muttering:
489029d1479882236-burying-generator-vault-into-bank-img_7218-jpg
Gettin after it!
489030d1479882236-burying-generator-vault-into-bank-img_7219-jpg
OK to cover :D
489031d1479882236-burying-generator-vault-into-bank-img_7222-jpg
Like it never happened.
489032d1479882236-burying-generator-vault-into-bank-img_7223-jpg
Infrastructure! Now to figure out a door and add the ventilation.
   / Burying a generator vault into a bank #69
Looking good Sodo! :thumbsup: Looks like you have some block work in your future as well? Yep, I imagine your going to be covered with snow for awhile very soon! Good luck and keep us posted.
   / Burying a generator vault into a bank #70
You should be able to pull new wire later through the conduit later when needed. Not hard to do with two 90 sweeps.
9202 (A50322)
9202 (A50322)
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
