Loader Reading Ignition switch Characters
/ Reading Ignition switch Characters #1
tbone2500
spokane, wa
Jinma 254 with y385 engine
I have a 1987 Jinma 254 Tractor with the Y385 engine.
My ignition switch is working but I bought this second and would like to know what the characters mean on the switch bezel. I think it may be wrong.
See attached picture
Thanks
Tom
/ Reading Ignition switch Characters #2
If it's an ignition switch maybe it's for a gas engine, since diesel engines don't have an ignition.
/ Reading Ignition switch Characters #3
G'day Mate and welcome to TBN from Downunder. Enjoy the site.
This is just a WAG but the "Q's" are in the right spot for the coil. The "O" is correct for off.
"Y" is for run/engine on, which leaves "D" for electrical on.
/ Reading Ignition switch Characters #4
Thanks
Tom
If it's like mine, Q is start, O is off, D is run and Y is pre-heat. You can start with or without pre-heat which is why there are two Q's.
/ Reading Ignition switch Characters #5
That's your reply?
Am I wrong here or are you being a smart aleck?
It sure seems like your just muddying the water with mentioning gas engine possibilities because you have an issue with the OP using the term "ignition switch"?
You know the OP doesn't know what the switch is and is asking for help, not playing a game of "gothcha".
It should also be obvious to you that's he uses the general term "ignition switch" since he mentions the "ignition switch" on his other diesel too.
BTW, the ignition in a diesel engine is controlled by this switch.
Maybe I'm all wet on what the intent of your post was, I hope so.
Thank you Quicksandfarmer for providing the answer the OP was looking for.
/ Reading Ignition switch Characters #6
That's your reply?
The generic term is Key Switch. Just let it go.
Thanks guys, I appreciate all info, it helps.
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
90in. Work Bench (A65640)
90in. Work Bench...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2003 Jeep Wrangler 4x4 SUV (A64557)
2003 Jeep Wrangler...
