Bh 77
/ Bh 77 #1
escavader
western maine
bx-23 ,
Joy stick knobs does any one know if they are threaded on? I need to shorten my sticks and straighten ,because I'm adding the seat I wanted originally.if so how would one loosen them?
/ Bh 77 #2
The knobs on the BH 75 are just pressed on.
My guess is the same for the 77.
/ Bh 77
Any idea how to remove them.i ordered the two replacement straight sticks but I need to swap the balls both type take same part number for the balls
/ Bh 77
What seat are you using for replacement.I have a B2650 with the Bh77.I hate the seat.
Oem seat and post and all hardware.mine didn't come with it because seat reverses on tractor.i hate flipping the seat back and forth.plus I have to sit on edge of it to reach sticks good . Ive also busted taillights twice because they are against my leg running it.
Beats the heck out of sitting on 5 gallon bucket which I've tried.
I sat on a 77 at a dealer display and had to have one.my opinion my 3300 should have came with it .but wasn't offered with the hoe to tractor mounting package.now I will be able to put this hoe on whatever kubota I might end up with in the future.it will have its own seat.
/ Bh 77
I have my seat and straight sticks.im much happier now.i don't have to reach for the sticks,don't keep breaking taillights from my body rubbing on them and I don't have to keep flipping the tractor seat around.
Now I'd like to come up with a solution for the wheels to remain straight and I can jockey the tractor around from the hoe seat
/ Bh 77
I can when I get home it looks like the factory setups for most tractors that came with the Seat on bh77
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
