Gear or Hydrostatic Transmissions for Compact Utility Tractors?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #361
And then there the fact that I can pull start my gear tractor...
For a seldom used tractor (I do have them) I don't need to screw with a batt. ect..., I can park it on a hill or give it a little pull, and with a little roll, it's off and running. A few minutes running gets enough charge in the batt., so it will start the rest of the day or even for a few days...
Yeaaa, I know, yuppie tractor owners wouldn't dream of doing such a thing!! lol
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #362
SR
I didn't think of that ! Good point.
I probably didn't think of it because in the 25 years I had my gear tractor, I never had to. :D
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #363
SR
That is one advantage to gear tractor I had forgotten. But I haven't done that since about 1970. :)
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #364
A dropped loader and 3 point implement puts a damper on roll starting. That's why jumper cables exist.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #365
I consider myself the TBN historical authority on this matter and with that everyone who has been here long will agree.
The answer is gear. No further discussion is necessary. (Is a smiley face really necessary here?)
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #366
Are you sure your the charter member?:)
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #367
For YOU...
BUT not all of us have or even want a loader on every tractor... And, THAT would be me.
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #368
Hahahahaa!!! :laughing:
I honestly can't remember the last time I bump started anything. It had to be in the 80's. For that matter, I can't think of anyone I know that has a stick in their car, with the exception of several young, male Mustang owners. As for tractors, I think that was 80's too, the last time I bump started one. Well, it was a tractor, sort of... it was a baggage cart tug at the airport. :)
Everything else we just jump started with cables.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #369
For YOU...
SR
Well, you just be sure and park your non-loader no attachment mounted tractor on that hill every time you plan on shutting it off, then. Sounds convenient. :)
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #370
Nope, not always... Just in the fall when I know it probably will be used for firewood...
Actually I've pulled a loader tractor to start it too, just run the chain under the bucket and it will lift it enough to bump start the tractor.
SR
TANK MANIFOLD (A55745)
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
204549 (A52707)
204549 (A52707)
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
2024 Frontier FL1061S Hydraulic Flail Mower (A56436)
2024 Frontier...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
