Yanmar2000
/ Yanmar2000 #2
/ Yanmar2000
/ Yanmar2000 #4
What exactly do you mean it shouldn't be a problem? Thanks.
I originally thought you had a 2 wheel drive YM2000. I then went to your profile to find you have a YM2000BD. My "shouldn't be a problem" was directed toward the two wheel drive axle. Sorry I am so confusing.
If your leak is not severe you might try using a little Lucas power steering stop leak in it. No harm should be done and it might seal it off.
/ Yanmar2000 #5
Is it where the halfs bolt at the differential or is it at the end steering knuckles? Those end knuckles leak fairly often I think and there are many on here that have documented the rebuild...not necessarily on a 2000 but similar small yanmars and I bet there all very similar inside. Search front axle leak or steering knuckle leak or something similar and I bet a few results pop up. Someone is bound to know of one off hand or has a link ready. I don't have time now to search for one though. I know Jake (JDgreen or something like that is his name here) did one on his like 186 or whatever model he use to have. A guy just tore apart his front axle in the last month or two, but I don't think he got to the steering knuckles his issue was in the middle and gears but had the axle torn down. Those are just off my head the ones I can think of but I know there is more.
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
Lot of (18) Hedge / Black Locust Posts (A66408)
Lot of (18) Hedge...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
2003 Kenworth T800 Log Truck (A62679)
2003 Kenworth T800...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
