   / Share Pics of People Hauling or Towing Something Wrong #4,331
Ya, minimum speed is 40 unless otherwise posted, usually 45 then.
   / Share Pics of People Hauling or Towing Something Wrong #4,332
He probably wanted to get them off the freeway. Driving at 35 is impeding the flow of traffic. Chipper should not need a plate, just a SMV sign.
Just noticed autocorrect changed Splitter to Chipper... the item towed was a very small Splitter.
   / Share Pics of People Hauling or Towing Something Wrong #4,333
Any towed implements on a public road behind a licensed vehicle need tags I believe. Would have been fine on a side road behind a tractor, but not a truck.
   / Share Pics of People Hauling or Towing Something Wrong #4,334
That varies by state,,,
In Virginia, ANY single purpose trailer does not need tags,
Items such as wood splitters, air compressors,,, etc are included.
The rental places are loaded with stuff like that, high lifts, steam cleaners, stump grinders,,,
all with no tags.
   / Share Pics of People Hauling or Towing Something Wrong #4,335
Three guys should have been able to to toss it in the bed of the pickup. .???
   / Share Pics of People Hauling or Towing Something Wrong #4,336
No... not without ramps or loading dock.
But one of the 3 should have had enough sense NOT to drive on the freeway... truck was set up as a landscaper's truck so being a business makes it worse.
Most definitely impeded morning commute traffic... and being in a city there are always plenty of surface streets.
I could easily envision make a hard turn it hitting a bump at speed upsetting the trailer...
   / Share Pics of People Hauling or Towing Something Wrong #4,337
all with no tags.
NY is the same way. Here, that also includes tow dollies, cement mixers, etc. The caveat here is that you cannot store anything in it (ie: no toolboxes built into or on the trailer unless they are empty) or it has to be plated.
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #4,338
Aaron Z
I have been using this for over 15 years,, 100 gallons of ethanol-free gas,,,
I just added the 50 gallon tank for diesel. (TSC had a 15% off anything day,,, I was hooked :thumbsup: )
The tanks are bolted down.
No lights, the only plate is a Farm Bureau Insurance "Farm Use" tag.
   / Share Pics of People Hauling or Towing Something Wrong #4,339
Hauling something wrong: some guy brought back a utility trailer loaded with gasoline he had bought cheaper in Texas.
He was doing maybe 45 on the freeway and got rearended by a semi.
Miraculously a little Honda that would have been crushed between them saw the semi coming and ran off the road at the last moment. No major injuries.
more photos CHP: Big rig crashes into SUV, ignites on fire
   / Share Pics of People Hauling or Towing Something Wrong #4,340
You better hope a VA State Trooper doesn't ever stop you. It's legal to haul diesel in those type of tanks, but not gasoline (or anything flammable). They come down on people hard for that sort of thing in my part of the state. There's probably a tag or sticker on the tank with the regulations, so you won't be able to claim you didn't know.
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
LOT OF 6" I BEAM (A58374)
LOT OF 6" I BEAM...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2012 MACK GU713 (A58214)
2012 MACK GU713...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
