Canning qustions
/ Canning qustions #21
I AGREE, do NOT water bath meat!
Yes, folks "use to" do that, but that was before some of these super bugs came along, it's NO LONGER acceptable whether the meat is cooked or not!...
Water bath canning will NEVER get the food inside the jars above 212* or so, and that's NOT acceptable.
I have two All American canners and we love them both!
I can all year long,
we love our own canned beans with ham in them,
much better than what's available in the store and much cheaper too...
SR
That's the same canner we have. The wife cans up huge batches of homemade soup and we eat it all winter. Good healthy stuff.
/ Canning qustions
I'm start tomorrow I still have the new jars to wash and I also have to wash the canner. I'm going soak the venison in salt water to get the blood out then I'll brown them. Blood and venison does not taste good.
/ Canning qustions #23
I know it's been said ,but again don't put the lids on too tight. If you do they will not let the air out and break. After the 90 minutes j remove from heat and do not take the jiggler off to relieve the pressure let it go down slow. Also some jars will sit for a while and then seal as the air is forced out by heating and as it contracts it creates vacuum and seals. If you take the lid off and some have not popped down just wait it out
/ Canning qustions
The book said finger tight then put hot jars on dish towel and wait for the pop then tighten the band.
/ Canning qustions #25
Once they pop you dont even need the bands . I leave mine loose so they won't rust on. Have had a few that were tough to get off.
/ Canning qustions #26
Here's my bigger All American,
They ARE a GREAT canner...NO rubber seal to replace, they are built for a life time ------> plus, of canning!
SR
/ Canning qustions #27
I think that's very wrong and you should re-read things....
Once they pop, they are sealed. If you tighten the band after the pop, you risk breaking the seal.
/ Canning qustions
OK so you put them away after they pop nothing else to do then?.
/ Canning qustions #30
One of my veggie recipes actually said to remove the band once the seal was confirmed (that "pop"). I don't because I can't eat the whole jar at once and the ring lets me save it for another day. All that said, finger tight before water bath and then leave it alone until you are ready to use it.
/ Canning qustions #33
We always remove the bands, clean the area up, mark the jars, then store. For use, we pop the lids and throw them away. We keep a couple of both wide and narrow plastic lids in the kitchen gadget drawer to use to put on partially used jars in the fridge. They are like these...
/ Canning qustions #35
With the questions you ask,, there are too many answers needed to be a forum question.
Safety is the issue,,
Get the Ball canning book. Follow it!! :thumbsup:
If you have any half gallon jars,, toss them, or use them to store old motor oil.
I use half gallon jars to can apple cider. If you hot pack it you just have to water bath for 15 minutes and you are done. I add ascorbic acid to make sure the pH is low enough. I would not use them for any low acid foods, but they wouldn't fit in my pressure canner anyway.
/ Canning qustions #36
I have another problem. I was boiling a pot of water with the jars they had water up to the rim and two of the bottoms broke off why? It said you could boil to clean them up.
I bet you don't have a wire jar rack in your canner. That's a trick, since they are sold with all canners.
/ Canning qustions #37
For getting blood out, you can't beat a marinade in cheap red wine. That's a critical trick in cooking liver too. The wine draws so much blood out it gets really disgusting looking, but the meat is wonderful.
/ Canning qustions
Keep them out of direct sunlight, and don't let them freeze. My garage stay above freezing, so all the canning jars get stored on shelves there.
My pole barn is heated now but I'll keep in the house.
