BX25 POST HOLE DIGGER REGRETS? For sale?
/ BX25 POST HOLE DIGGER REGRETS? For sale?
Speaking of possible engineering designs, CLICK HERE
to se some ideas. Notice their is a LOT more welding involved
thus raising production costs BUT, will this not fit more tractors?
And the price is WAYyyyyy right IMO.
PS, I am not a shill for TSC , I just ran into this looking after Milkman's interjection.
CAD = Perfect, do the math Ted! It will end up making you BIG $. IMHO sir.
In all honesty, I do not know whom owns the "Countyline" TradeMark.
Is it Tractor Supply Company and how do you know this?
/ BX25 POST HOLE DIGGER REGRETS? For sale? #14
Notice that the price does not include the auger.
Bruce
/ BX25 POST HOLE DIGGER REGRETS? For sale? #15
Thank you Fallon.
Ted try's really hard, that is for sure, but in this case I wish more R&D had been done,
and, a video before final design and paint concerns me. I am sure there is a way to
make a 48" bit work. Guessing on how to do it w/o CAD design is just that, guessing.
Also the 1000 mile shipping deal is a big roadblock. It is always an extra.
I believe the biggest complaint on a 48" bit is the bit dragging in transport mode.
There is an easy fix I do believe, that being a tether or a way to pin it at an angle for transport
even if that means the PTO shaft has to be extended or disconnected. Not complaining or
chastising mind you. ETA is awesome, for East coast folk.
You can install a 48" auger on the Land Shark Subcompact PHD.
On FLAT ground, it will have 8" of clearance with the BX 2670's lift all the way up. Results may vary on other subcompacts.
The boom is short and closer to the tractor, so lifting ability is magnified.
We have put plenty of R&D into our post hole diggers.
Our EA compact tractor PHD features a 48" long auger and has plenty of lift height on any subcompact.
BUT the boom is longer, so the tractor's ability to lift it is lessened.
People on the left coast are usually very surprised by our outstanding shipping rates. Most of our PHDs ship to your home via Fed Ex Ground. No Tax.
I hope this makes sense. I typed it during and in between phone calls and website chats. :laughing:
Travis
/ BX25 POST HOLE DIGGER REGRETS? For sale? #16
Let me go through my education on post hole diggers and where I"m at today. I started out with a cheap Leinbach Line post hole digger that my dealer sold to me at cost when I bought my 35 hp tractor. I think it was $295 for it with a 12 inch auger. At first, it worked good, but the clay quickly wore off the cutting edge. I found replacement cutting edges on ebay and went through those rather quickly. I tried adding a bar to the end of the auger and having a friend pull down on it for more pressure with some success, but it was a lot of work. I then tried welding on carbide cutting teeth to the auger with the hope they wouldn't wear out so quickly. That worked, but not great, and eventually wore out too.
Then we got an Atwoods store and they carried Speeco auger bits with replaceable cutting teeth and a spiral drill tip for $100 that was a perfect replacement fit for my auger. It was night and day better. No need for extra downward pressure, it just worked its way down all on it's own. Unfortunately, it the cutting teeth didn't last very long and I was constantly buying new ones.
Then one weekend when we where almost finished fencing in our horse pasture, and in a rush to get it done because we where getting the horses real soon, I needed more cutting teeth and couldn't find them anywhere. In desperation, I went to Tractor Supply and bought their Country Line auger, which also had the same sized shaft and hole alignment as the Speeco and Leinbach Line.
The Country Line went through the hard clay like butter. In fact, it drilled down so quickly that the new challenge was in not burring it. It might be too aggressive, but compared to augers that do not cut, or dig, it's a good thing.
In 15 years of learning all this, I've come away with realizing that it's all about the cutting teeth. The gear boxes are all the same, the flutes are all the same, the driveshafts are all the same, but the teeth are not. The Country Line auger teeth get the job done!!!!
/ BX25 POST HOLE DIGGER REGRETS? For sale? #18
Indeed I see the short drills will be an issue.
Milkman do you know the model number for that PHD and
is that bit a 40" or 48" ?
I will check the model# and length of the bit.
Edit:
The PHD is a SpeeCo model 70, the ones like the Speeco model 65 won't work on my BX because the attachment point for the pole to the arch is different and it will bind because of lack of clerance between the pole and the arch. I will get the length of the bit I used when he gets home from work, I'm 99% sure it is 48".
2022 Caterpillar 289D3 (A60462)
2022 Caterpillar...
(INOP) GRAVELY ZERO TURN LAWNMOWER (A59823)
(INOP) GRAVELY...
2017 Case CX145D (A60462)
2017 Case CX145D...
2016 Chevrolet Tahoe SUV (A60352)
2016 Chevrolet...
2011 DOOSAN G40 GENERATOR (A60736)
2011 DOOSAN G40...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
