Update on deck coated with bedliner
/ Update on deck coated with bedliner #21
Has anyone done the interior of a mower deck?
You would trap moisture and create more problems with rust. I pressure wash my underside mower deck every now and then before winter and spray penetrating oil on it when it's squeaky clean. Seventeen years later it looks the same as one about two years old.
/ Update on deck coated with bedliner #22
I do like this idea, I may have to coat steps and step plates on tractor and backhoe.
/ Update on deck coated with bedliner #23
/ Update on deck coated with bedliner #24
I used rattle-can Slip Plate Amazon.com: SLIP Plate(R) Aerosol, 12-oz: Automotive on the inside of my mower deck. Spray on a couple of heavy coats, let dry, then burnish with coarse steel wool to polish it slick. Depends on what you mow but mine lasted almost 2 year per application. It stays cleaner and more easy to wash off. Also in brush cans.
So, is that slicker than just bare steel? If so, I wonder if it would work in a snowblower chute to reduce friction/clogging?
/ Update on deck coated with bedliner #25
Answers: yup, I masked it off, and just stuffed some newspaper pieces on top of the hardware below the holes so it wouldn't get painted. The center cover was taken off, masked and sprayed. I used this stuff, from NAPA... and I would use it again, if a need arose.
Just a caution about the Dupli-Color product. I used it on my truck bed when new in 2004. I now have a large rust thru on the wheel tower I need to repair. The coating is pretty good and fairly tough but it is not flexible. Dents on my bed cracked the coating and rust went through those areas before I realized it was rusting. If you use this kind of material on a surface that can be dented, be sure to check for cracks and recoat to keep it sealed.
/ Update on deck coated with bedliner #26
Can't argue with that track record! :drink:
You might want to look at Fluid Film. Seems to be really good stuff. I'm finding it very effective.
/ Update on deck coated with bedliner #27
Ag stores sell a product--I thought it was "Slip Plate" as well but it was in a different can. Anyway, dirt slides right so maybe snow too? If it's cold enough, I have heard that PAM cooking spray oil keeps a snow blade clean and the snow slides off better.
/ Update on deck coated with bedliner #29
That's a nano-particle application. I've read it washes off pretty quickly. Works amazingly well while it's there, but it's not there long. If they get that problem solved, it will be a great thing.
/ Update on deck coated with bedliner #30
If you want to bed liner something at home check out "Raptor" bed liner. It is a two part mix that is super simple to mix. Take part one and dump in the bottle to the line, shake for 1 minute then spray it. I have used it on a Mule, several implements, a few tractor floors, hitches and a couple other things and it really holds up great. It is SUPER easy to shoot it if you have a compressor - when you buy the $99 kit you get the gun with it (the kit is supposed to cover a full truck bed). Takes basically no skill (not like painting a car) to shoot it and you can control the thickness. I even did my reloading bench top and it seems totally impervious to gun cleaning chemicals and such.
/ Update on deck coated with bedliner #31
Should get it professionally line-x'd! That would be great!
/ Update on deck coated with bedliner #32
Don't do that . There is a better way. Just google up the topic on youtube. You will find the real answer is making seals on the impeller where it goes around in the back. Just remove the top chute and use some old mud flaps cut into strips wide as the impeller and around 2" in. Screw them in with self tapping sheet metal screws so they are just dragging. Put back together and you can run it a bit and the excess wears off. Now your blower never plugs and snow throws like you see in the ads, REALLY!!!!!!! So simple and cheap yet works so darned well.:cool2:
/ Update on deck coated with bedliner #33
Had the truck bed sprayed professionally. Best decision ever. That kinds of stuff holds up like crazy. Did not realize they sold it in a spray can. Got a few things over the years I have though could use a coat of bed liner. Now I know I can do it. Thanks!
/ Update on deck coated with bedliner #34
Does the raptor liner end up slippery? I have a snowblower chute that needs painting and that might be the ticket...
Aaron Z
/ Update on deck coated with bedliner #35
The Raptor liner is not real slick, so I don't think it would work too well for that. It is the closest thing I have found to LineX or the other commercial bedlinners. Leaps and bounds better than the stuff in the spray can. I touched up my LineX bed linner with it and you really can't even tell where I did the touchups.
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59910)
2014 HYUNDAI...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
