Finally added hydraulics to my BackBlade
   / Finally added hydraulics to my BackBlade
Sorry guys, didn't have a chance to reply earlier. The rod is 1.125" thickness. Stroke is only about 8" (closed length is about 18.5" pin center, open is around 26.5")
I'm not worried about a relief in this application. The "bracket" I welded onto the "turntable" was welded so that it should fail before anything serious breaks.
   / Finally added hydraulics to my BackBlade #12
Really need to know the cylinder diameter.
It's a pretty fat cylinder, I'm guessing somewhere around 2.75" to 3". I peeled the sticker off a couple years ago, but I want to say it was rated around 10,000 lb straight load. I'll have to look it up to be sure.
   / Finally added hydraulics to my BackBlade #14
Once you know cylinder diameter (or in this case the load its rated for)....its pretty easy to size if its big enough.
The blade, and center pivot.....think of that as a lever. Like the handle and pivot on a bottle jack. Now look at the cylinder as that little pump.
IF its an 8' blade, you have a 4' lever.
If the cylinder mounts are 1' out from the center pivot.....then you have a lever w/4:1 advantage.
TO equal 10k at the cylinder....only takes 2500# at the edge of the blade.:thumbsup:
Cylinder sizes, where its attached (how much advantage), etc. Can all be adjusted to get whatever strength you want.
Landpride RBT35 series blades comes with a 3.5" x 14" cylinder. Thats good up to ~65HP 4wd tractor
Their 45 series, blades use a 4x16 cylinder
Ok, thx for the info... I'll measure the cylinder later
   / Finally added hydraulics to my BackBlade #16
I sold that white F250 V10 a couple years ago now, have had that F450 6.0 PSD since. BulletProofed it this spring.
Although I also just picked up this '89 F250 plow truck...
How's the LS holding up? And how's the 6.2L working out in that new truck?
Lol i meant F-450, I see it no longer occupies your signature. Your "new" plow truck looks "experienced." I have been busy with college and haven't been to the farm in a month, but the LS was doing fine a month ago. As to the 6.2L powered F-250, that pickup has not seen daylight since mid June. :eek: We bought a 6.4L Powerstroke powered F-250 thats been driven a lot lately.
   / Finally added hydraulics to my BackBlade #17
If you are gonna do something that might cause high force on the blade,,,
simply use the blade angled so that the cylinder is closed.
About 80%+ of these failures come from bending the rod of the cylinder during overload,,,
pretty difficult to do if the cylinder is retracted.
The other 20% of failures will be a burst hose,,, an easy, but, messy, fix.
My first loader had a single cylinder retrofitted into the bucket tilt,
it was a retrofit by the previous owner to replace the original dual cylinders.
I burst so many hoses, that I kept a spare in the shop,,,, :laughing:
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A51039)
2022 Quick Attach...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
