Bar and Chain replacement
/ Bar and Chain replacement #1
prichard
N. Georgia
B2601 FEL
I have a Husqvarna 455 50cc saw. .325 pitch 18" bar.
What is a good replacement bar and blade? There are so many brands out there. I was thinking of going with Oregon, thoughts? Also, what's the max bar length that saw can handle?
/ Bar and Chain replacement #2
I have a 450 that has a 20" bar never replaced the bar if I did I would go with Oregon.
/ Bar and Chain replacement #3
Look in the manual or look at the max bar length that Husky sold the saw with. That said, there is no sense in getting more bar than you need. I get by with the 18" bar on my 346XP just fine and that includes cutting 2 1/2' to 3' oak logs into rounds for splitting.
/ Bar and Chain replacement #4
I'd go with an Oregon bar most likely. A Total Super would be good too. I've been liking 3/8 lo profile better than .325 lately, myself. Fewer cutters, and a little narrower kerf. You'd have to swap sprockets too, though. If you haven't done that lately, it'd be good anyways.
Personally, I'd run a 16" .325 or 3/8lp on that saw. Might try an 18" in 3/8lp. At the absolute outside, you could run a 20", but it'll be unwieldy, and underpowered with the bar buried.
/ Bar and Chain replacement #5
Oregon has different grades of bars, get a better one. I just got one for a 55cc Echo with .325 chain. I didn't think of it time plus I had a bunch of chains for it, but I would go after a better bar that uses a 3/8" chain even though you need to change the sprocket. Better for chewing through wood.
/ Bar and Chain replacement #6
Regular 3/8 (not lo profile) is a little much for a 50cc saw, in my opinion. Maybe if you're running a 12-16" bar or cutting softwoods.
/ Bar and Chain replacement #7
I've got a few chains at Frawleys Saw Shop, quite a selection. I run .058 ga. .325 pitch on 18" bar on a Husqvarna 550XP, just them extra 2" on the makes a difference on my back...........
/ Bar and Chain replacement #8
"IF" your saw needs a bar, it also NEEDS a sprocket too!
I pretty much hate .325 chain!! I MUCH prefer 3/8 chain, and I now have all my saws switched over to it. It stays sharp longer for me, and is easier for me to sharpen...
I use Oregon brand bars and chain...
SR
/ Bar and Chain replacement #9
I have 3/8 on my 550XP and it runs it like crazy, even in hardwood, like this Beech!
SR
/ Bar and Chain replacement #10
I run 3/8 on both of my saws. 3/8 is a little big for the little saw, but it stays sharp longer and is easier to sharpen. When the little saw starts to bog I get my bigger saw. I run 20" bars on both my saws. I have a 28" bar for the 372XP, but it makes the saw nose heavy. It's much better balanced with the 20" bar. The 28 cuts a 21" log a lot faster though. I run a 20" bar on the 353 because I found a deal on chain that fits that bar. Otherwise a shorter bar would be better suited. The 3/8 cuts faster than .385 as long as you have the power to pull it. I hurt the performance of my Husqvarna 353 on stuff bigger than about 8-10" with the 3/8 chain, but I can live with that. The 372 cuts 8" or large stuff way faster regardless of what chain is on the 353.
/ Bar and Chain replacement #11
SR
Yeah, I like 3/8 too. A 550xp with a short 3/8 bar would be an awesome setup, but the 550 is a bit of a factory hotrod. I think most users and most 50cc saws are probably better off with a smaller chain. But hey, bars are pretty cheap for those little saws. Buy a couple different setups and try them out.
Just my opinion, though.
/ Bar and Chain replacement #12
I also have 3/8 on my Husky 55, it also runs it like crazy...
It's my most used firewood saw...
SR
/ Bar and Chain replacement #13
For simplicity, I run 3/8" on all my saws. I know many run .325 on Stihl 260s, but I run 3/8-never a complaint. If I need more saw, I just grab my oldHusky 66 or my Stihl 461.
Will
Thank you all. Probably stick with 325 on 18 bar but may get a 3/8 setup to try.
/ Bar and Chain replacement #15
I have a 455. It came with a 20" bar and 3/8 chain. It was underpowered.
I still run 3/8, but on a 16 or 18 bar depending on what I am cutting. Best decision I made for that saw.
I have looked at narrow kerf, low profile, and 325. I stayed with 3/8 only to be consistent with my other two saws.
/ Bar and Chain replacement #16
I just replaced the bar and chain on my dad's 4600 Echo with a 16" Oregon .325. It specs at 18 and .325. I had to go to a full service dealer to get full chisel chain. Most big box stores only sell low or reduced kickback chain anymore.
/ Bar and Chain replacement #17
Lowes has both Husky and Oregon brand bars and chains up to 24". They sell both the 455 and the 460s at the MSRP. The 455 comes with a 20" bar, and the 460 has the 24" Oregon comes in a two pack. About 40% less than Husky. Due to no feeling in my fingers I an not able to sharpen any more. 2 new Oregon Chains are cheaper than sending out 3 chains to have sharpened. Chains and bars at Lowes are much cheaper than at the Husky dealers. Check Amazon for chains also they have the Oregon line.
Ron
/ Bar and Chain replacement #18
Agreed. 20" is really pushing a 50cc saw. Be kind to your saw and it will last longer.
Oregon is good stuff. You won't go wrong there.
I have been committing heresy myself, the last few years. I run Stihl chain on my saws, including the orange ones. Holds the edge better than lesser chains.
I'm not a fan boy who thinks Stihl is the ONLY good brand. I just took the advice of a lot of pros, including die-hard Husky men, and I'm finding it's working out well for me.
/ Bar and Chain replacement #19
Yep, people tend to agree that Stihl chain is a little harder and stays sharp a little better. It's also a little tougher to sharpen, and quite a bit more expensive. From my dealer at least. I'm running stihl chain on my regular 3/8 bars, Oregon on my .325, and Carlton on my 3/8lp. I actually like the Carlton pretty well. Bailey's sells it as Woodland Pro, but it's just rebadged. I got mine for half the price of Stihl.
/ Bar and Chain replacement #20
I have the 455 that came new with a 20" bar. It only bogs down when you fill the bar but I rarely do that. My son thought he'd bent my bar so I researched around and ordered the following based upon reviews I was able to find online. When I finally examined my saw and cleaned it up following my son's use all it needed was sharpening. 5 min. with a file and I was good to go. New bar and chain are in the barn read for when I ever need them.
Oregon #200RNDK095 bar, #72LGX072G full chisel chain
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
4022CFL (A59228)
4022CFL (A59228)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
