Trac Vac mods
/ Trac Vac mods #1
ditzel
N.J.
Mahindra 2615 Gear
IMG_20161015_132903.jpg[/ATTACH]IMG_20161015_151248.jpgIMG_20161015_130647.jpg/ATTACH]IMG_20161015_150110.jpgIMG_20161015_151138.jpgMy vac seemed to be blowing a lot of debris out of the wire mesh top. So today I made up 2 screen type inserts to help reduce the amount of particles it spits out yet still let air exhaust from the enclosed trailer. I sandwiched mesh screen between 2 frames made out of azek type plastic, for the mesh I used a few cheap fluorescent orange traffic flags.
/ Trac Vac mods #2
So do you just tap on the orange filters and the collected dust and what not falls back down into the trailor when your emptying it ? Or do the remove somehow to clean up ? Or do they even hold much dust ?
/ Trac Vac mods #3
ditzel,
Have you used it enough with the new filters to get a feel for how much they reduce the air flow? Cutting down the trash blown out seems like a good idea. But I use mine without a mower to pick up leaves from the ditches along my driveway, and it sometimes plugs as is. I wonder if they would reduce air flow enough to make the plugging worse?
/ Trac Vac mods
So do you just tap on the orange filters and the collected dust and what not falls back down into the trailer when your emptying it ? Or do the remove somehow to clean up ? Or do they even hold much dust ?
Yup, just tap it and it falls down. I originally was going to mount the screens outside on top of the trailer;s wire mesh, but after thinking about it, debris that could fit through wire mesh but not through the screen would get trapped.
/ Trac Vac mods
ditzel,
Just finished making it yesterday and tried it for a little while, I did not notice any reduction in airflow, and no clogging yet. I will be using it today and will see how it works, I'll keep you posted.
/ Trac Vac mods
Filled it 3 times today, no problems with clogging or anything. Worked like a charm.
Unverferth 275 (A64126)
Unverferth 275...
ALUMINUM TOOLBOX (A64277)
ALUMINUM TOOLBOX...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
7' Disc (A62613)
7' Disc (A62613)
