Best method for a tractor to move/haul/process downed logs?
   / Best method for a tractor to move/haul/process downed logs? #41
Xfaxman: I was referring to the width of the trail not the grapple, out in a field it wouldn't be a concern as your pictures show well. It would be an issue if it was in the bush where the trail is only as wide as the tractor. IE: 8 foot wide path and a 20 foot tree, it wouldn't work with a front grapple unless you could cut the logs down to be able to fit through the trail.
   / Best method for a tractor to move/haul/process downed logs? #42
This is what I used to move logs. These are white and red oak logs. The largest is 27 inch and around 9 foot. fresh cut and approximately 1 ton. I moved these from my woods in about 4 hours with a little Kubota B7100.
   / Best method for a tractor to move/haul/process downed logs? #43
It's only 8 acres of his 88 as I understand it. And no rush and not in a production setting.
Sure, a tractor with a grapple isn't the best choice for clearing forested debris, and certainly not what a professional would choose.
But it's not exactly like a non-professional homeowner is gonna go out and buy dedicated forestry equipment to clean up 8 acres of his own land and then have no use for the equipment. How well is that expensive forestry equipment or tracked skid loader gonna mow his 20 acres he mentioned.
I didn't say dedicated forestry equipment. You can get the same features in most construction type of equipment. Things like skid plates, protection for the engine, protection for the operator, heavier tires, etc... Even those little rental backhoes are built like a tank compared to modern CUT's.
Like I said earlier if you are going to do anything more than light duty stuff I'd look at somethign different than a tractor. There are no skid plates, tires are light duty, lacking protection for the operator, no protection for the engine unless you think that flimsy hood is going to do something, etc...
I think using a brand new tractor for somethign like this is just a bad idea but you never know these 24" logs that are 25+ ft long may be few and far between but that is big enough to give a CUT trouble, especially trying to carry with the loader. All that weight on those little tiny tires is a recipe for disaster unless it is really flat and really firm ground..
But I have no doubt that a tractor would work if you were really careful and the situation was not a snarled mess of huge trees knocked down laying in all directions with debris like sharp sticks laying all over the place on somewhat uneven terrain.
   / Best method for a tractor to move/haul/process downed logs? #44
Here's a small sample of what I was dealing with.
Maybe similar to Plowhog's, but hopefully no root balls?
The only way to realistically access any of this was to pull out one "stem" at a time. The only way to do that with a tractor is to take advantage of its TRACTION to pull, either with a choker and chain or a winch. Even so, no way the root balls from blown-down trees were going to be moved without being able to get to them to cut the "stem" loose first.
No way to get in and do any of that with a grapple. An excavator with a grapple to do it from over head, maybe. But not from tractor level.
   / Best method for a tractor to move/haul/process downed logs? #45
Sometimes you have to do hand-to-hand combat! Geez, I'm old and I get out and swing my trusty machete. Chainsaw stuff!
Whenever you have a problem cut it down to size.
JPRambo, the "little" Kubotas are awesome. If you are really good you can make them work VERY hard. They can get into places where nothing else can go. My wife is now referring to our B7800 as the "toy tractor"- I am more than quick to snap back with: "it's NOT a toy!" (yes, she understands and says this jokingly, but I insist upon not treating it like a joke)
   / Best method for a tractor to move/haul/process downed logs? #46
here one more comment to a fine list of comments. Give some serious consideration to using an older tractor like the 4610, 6600 series , or 7600 series. For one thing, the ground clearance is greater that some of the newer kubotas. Second they do not have as many hydraulic lines under the tractor as many of the newer tractors do. Hydraulic lines & brush = repairs. Though they are not as fancy, they will endure a lot of hard work and are much simpler to repair. Get a logging winch, you will be much more effective in tangled brush. I have a 30 hp tractor with a norse winch and and would not hesitate to hook it to a 26" log; though I would limit the length to about 12 ft because you will not turn a long log without a wide area to work in. 20 acres of mowing is only about 2 long days with a 7 ft bush hog. Good Luck. W. Jones
   / Best method for a tractor to move/haul/process downed logs? #47
My point was.....none of the construction-type equipment you imply, or skid loaders, or anything else not on tires, is not gonna serve him well for the 20acres of field that will need mowed regularly.
As I understand it, cleaning up this small 8 acres of mess is gonna be a one time deal. So my suggestion. Is to buy what you will need for the future, and make it work for this one time cleanup.
You keep mentioning small front tires, guess that's all relative. Tractors, once you get much north of 50hp, don't have what I would call "tiny" front tires.
Actually, HP for HP, backhoes have about the smallest front tires you will see.
   / Best method for a tractor to move/haul/process downed logs? #48
Just not true at all.
Ford 4610...............60HP.......4800#........14.9-28 tires........17.3" ground clearance
M6060 kubota.........60HP........5000#.........16.9-28 tires......18.1" ground clearance
Ford 6600...............79HP.......5880#..........13.6x38 tires......18" ground clearance
Kubota 8560...........85HP.......5800#..........16.9-30 tires.......18.7" ground clearance
Ford 7600..............93HP.........7440#..........16.9x30 tires......18.2" ground clearance
M9960..................100HP.........5950#.........18.4x30 tires.......19.7 ground clearance
   / Best method for a tractor to move/haul/process downed logs? #49
You are certainly free to believe that a new tractor is the best way to approach 8 acres of logging downed 24" trees but I don't. I have gone over the reasons why I dont' think it is but its' clear that you see this differently and that is fine.
My experience comes from doing actual logging of material this size and running a full sized skidder. Loggers approach things differently than landowners do.
And yest CUT's have tiny small front tires which end up carrying most of the weight when doing loader work. That is a fact. I had a 45 HP tractor and the fronts were severely undersized for carrying loads. When you feel the back of the tractor get light you know that the majority of the weight on on the little front axle.
If you want to believe that backhoes front axles are undersized and the tires not fit to carry heavy loads you are entitled to your opinion. From my experience running construction equipment it is built to a different standard and designed to take a beating doing hard work much more so than a CUT.
A tractor is designed to pull heavy loads so if the OP goes with a tractor I would try to find a way to drag material out as opposed to carrying everything out. That will also allow more flexibility in getting close enough to hook up a chain or cable as opposed to having to drive right no to the downed tree to get it with a grapple. I would leave them whole and then cut them up and use the grapple once you get them out.
   / Best method for a tractor to move/haul/process downed logs? #50
We arent gonna get any where arguing with each other.
1st, I never said a new tractor was the best idea. And never argued against a used tractor. A used tractor loader would be a good combo, especially if 4wd. But since day one of ownership of a new tractor, and a newer gently used tractor, mine has been in the woods with me cutting wood. So I have nothing against that.
2nd, I never said anything about axles. Your earlier comment was about tires. The M6060 the op has looked at, comes with 9.5-24" tires. Which is LARGER than anything you will find on a backhoe except for the the ones like JCB. I have a 18000# backhoe, I understand fully the difference in how construction equipment, and ag/utility tractors are built.
This isnt meant to be a debate between what is better at logging type work. Clearly, a skid loader, or other construction/forestry type equipment is king.
My point is, we are talking about a small 8 acres, one time, that is in no rush to get done. And there are a vareity of other tasks that he needs for his property. That $75 tracked skid loader with grapple is not gonna mow his 20 acres. A M6060, or similar new OR used tractor WILL. And it will ALSO handle his small 8 acres of clearing needs. Sure, not as well as other equipment. But whenever getting equipment to do multiple jobs, there are always trade offs and compromises.
If money were no object, I'd own about a dozen more pieces of equipment myself. But reality is different. For me, a tractor covers the broadest spectrum of tasks that I need accomplished. I feel the OP's situation is similar. In that if he were to get a tracked loader, either new or used......he would still need a tractor. And be left with a seldom used piece of equipment once the 8 acres is cleared.
2011 ELITE TRAILER 20 T/A GOOSENECK (A55745)
2011 ELITE TRAILER...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
