The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,331
Travis I want to correct something. I am passionate about my girlfriends and my teddy bear. I am merely interested in grapples and tractors.
I argue the small is beautiful line on grapples repeatedly for a simple reason. The folks participating in these discussions are generally looking for their first grapple and it is very very easy to be misled into buying more grapple than you really need and can use efficiently.
Despite the sniping by a few who bought big grapples, the evidence as presented by many dozens of grapple owners here on TBN consistently supports the notion that a small lightweight grapple does just about anything that a CUT owner would want to do with a grapple. That doesn't mean small lightweight makes sense for a contractor running a big skidsteer and it doesn't mean it applies to a utility tractor in commercial agricultural use. It does generally apply to the typical TBN CUT owner who has a tractor that can be towed on a 10,000lb trailer rig, has a loader lift of 3000lbs or less and generally fits the compact utility tractor designation (I used to say 50 hp but lots of CUTs now have 60hp even though the weight and loader are the same as their less muscled sibling tractors). Finally, it is just a rule of thumb. You might have a very good reason for some other type of grapple but recognize before you shell out $2500-4000 for a monster grapple that most everyone with a narrow lightduty grapple finds them to be just about perfect. Several guys with more than one grapple size say they'd choose the narrow lightduty if they could keep just one. Point is that grapple newbies should not get caught up in the "more horsepower is better" race when it comes to grapple selection. Think about the physics and review what tasks small lightweight grapples are capable of before shelling out more bucks for a grapple that might well not be as useful to you. Then, if despite all the evidence presented to the contrary, you still believe your manhood is really reflected in the size of your grapple, buy a big grapple. I'm sure the girls will be impressed.:laughing:
I'll give it to IT, this was one of the best posts with great insite into his views I've ever read. I guess I understand a little better why he preaches so much and I guess since he's on an EA thread he still encourages buyers to buy EA so for that I'll say good info
Brett
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,332
I was browsing the EA website last night and looking at grapples for my tractor. I was torn between the model that was for tractors up to 75 HP as my tractor is just under that. But I was also looking at the Extreme duty as my tractor has a pretty good lift capacity as I have lifted over 5,000 pounds at 24" with it.
So as I am reading the reviews for the Extreme Duty the very first one is exactly what IT was talking about as far as fitting the grapple to the tractors capacity.
Construction Attachments XTreme Duty Root Grapple For Skid Steers and Larger Tractor Loaders
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,333
Yes, but... That product group is specifically for Skid Steers. Folks here are primarily talking about the sizing on EA WICKED Root & Debris Grapples. I bought the 66" version, which is 410 lbs. The skid steer 66" one is 862 lbs!. THAT weight difference IS significant. However, along the CUT product group (what this thread is about) and the single lid grapple the smallest Wicked grapple is 54" and weighs 349 lbs, about 60 lbs less than the 66" one that I bought: to put THIS in context, it's roughly a 2% "hit" in lift/weight capacity for my loader on my yet-to-arrive tractor (54" vs 72" would be about 3%). For myself weight was not an issue (in this product group), width was.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,335
Yes t's a perfect example of matching an attachment for a piece of equipment, in this case a tractor. It says for skid steers and tractors and is easily someone with a tractor that had some power might look into. I thought it was interesting reading it after IT made that exact point. I know I would consider it my my little CUT.
You found what works best for you without losing much capacity. That's great. But some of us like a machine with some real lifting capacity which requires a heavier grapple. You seem to suggest that my posts are off topic just because my tractor has a different lift capacity than yours. I"m not off topic so stop whining about it.
Roadhunter, your JCB is a cool looking ride. I can't find any good specs for it online.
Will you post some pics of it?
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,337
Travis
I"m glad you asked as I was looking at the options and saw a Euro QA for $125. I think that may be what I have on the JCB.
It has just under 70 HP and I believe with the tries foamed is somewhere around 13,000 pounds. I know the 4 in 1 gannon blade/bucket is pretty heavy which is why I was looking at the 2 heavier models you make for tractors up to 75 hp and the other for skid steers and larger tractors. I think the lifting capacity is in the 5,000 pound range.
Ah man. That's a different animal. It's definitely not euro because the top hooks are wider than the bottom pins on a euro.
I do not even have a source besides Bradco/Paladin and it'll be heavy and $$$$$.
Here's an adapter to convert it to universal skid steer QA, but it's $2,000 alone!
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,339
I was afraid of that. This setup is pretty heavy duty compared to a skid steer.
It almost looks like the euro brackets would work if I reversed them to make the top narrower than the bottom. I'll have to look into the diameters.
I made brackets for my fork frame with a set of over the bucket fork brackets.
We could make a grapple for you with no mounts if you have the ability to make some.
By the looks of that bucket, I'd lean towards an Xtreme duty.
We do have the heavier Wicked Grapple which hasn't made it to the website yet.
Travis
BRIGGS & STRATTON CLEAR SHOT PRESSURE WASHER (A57192)
BRIGGS & STRATTON...
3ft 5-Point Metal Star (A55853)
3ft 5-Point Metal...
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A57193)
UNUSED SDLANCH...
Gehl Mix-All 125 (A56469)
Gehl Mix-All 125...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
