5570 - Serious problem and I need some good advice
/ 5570 - Serious problem and I need some good advice
Nothing major. I am actually off the farm running my other business (you know, the one that supports the farm). After charging the battery (again) the tractor tried to start (again). This time I am told it sounded just like it would if the battery was darn near dead - you know that half-hearted-you-know-you're-not-going-anywhere sound. There's lots of other tractor-not-needed projects that are ongoing, so my son is handling those until he has a chance to get back to my temporary lawn ornament. I'll be home next weekend and if a new or known good battery has not been acquired by then, I'll be trying that before pulling the starter.
Good news is the motor turns over by hand and appears to have compression - it's definitely not easy but it is smooth. I promise to post when something of note happens.
And, with regards to a starter, I darn near had a heart attack when I saw the price of a OEM starter. I am going to see if a- it is a warranty part and b - I can just take the starter in as it's a royal pain to haul the tractor in just for that. In the meantime, if one is needed, I will be buying an after-market starter.
/ 5570 - Serious problem and I need some good advice #22
If it's any consolation, an 18" long piece of plain old thin exhaust tubing for the stack above the hood on my Kubota is $180 and a plain, old everyday non-emissions-muffler almost $1,000. So there are two more things that aren't going to happen before heck freezes over.
/ 5570 - Serious problem and I need some good advice #23
Here is an unrelated example of part price insanity.
A Pulsafeeder Chemical injection pump.
Cost to purchase a cheap little PVC injection valve body with Stainless alloy steel Spring and ceramic ball, Plus a rebuild kit, basically gaskets, cost more than the entire new pump assembly which included valve, All fittings tubing, Pump head and motor.
I swear some items Kubota and others sell are marked op 3000 to 10000%, general industry practice is about 300% on larger items to about 1000% on the little stuff. You got to cover inventory, handling and processing and make a profit, but sometimes greed and stupidity, take precedence.
/ 5570 - Serious problem and I need some good advice #24
Years ago I had a major maker disc harrow that I really liked to decided to look into rebuilding it. The parts were so insane I wrote the company. A left rear bearing that at the time might have been $85 (for a $15 part) as an example but the EXACT SAME part that also fit the right rear was something like $265. The exact same part. It's been years so I don't remember the exact prices.
Other parts were the same and even though the left and right were mirror images, the prices were all confused. The company wrote me back and thanked me for the heads up. I'm not into the education business so I sold the discs and bought one built out of fewer proprietary parts. It would have cost a silly amount to rebuild and it wouldn't be long before I would need something else and be right back in the tank again. Adios, beancounters.
/ 5570 - Serious problem and I need some good advice #25
I had an uncle try and help on the farm years ago, he was going to move the TD14 IHC (starts on gas, switches to diesel) crawler to the shop. It would not start for him (he forgot to turn the gas on) so he pulled the spark plug wires and distributor cap, figuring he wasn't getting spark for some reason. He put it all back together without paying any attention to the order of the wires... When I finally had a chance to go look at it, they had pulled it trying to start it (none of the settings were right to start it).. I spend about 10 minutes putting the spark plug wires back on correctly and checking things, got on it and it started right up on gas, warmed it up, switched to diesel and drove away. That uncle is still clueless to this day, over 30 years later..
hope you get your tractor running..
/ 5570 - Serious problem and I need some good advice #26
Wow- bought a factory style replacement for my 3000 was $28 and checked on a factory new one for My Rhino was all of $88 and thought that was a bit steep
These guys seem to be taking clues from some of the less scrupulous drug companies:laughing: - maybe that isn't funny
/ 5570 - Serious problem and I need some good advice #27
MSRP on a complete short block is $5244.60 plus freight. That is complete with oil pan, front gears and cover, of course crank, pistons, etc. You would have to swap the head over and all accessories, fuel system and so forth. Still a ton of money, but it is $21k less than what you were quoted.
I still doubt it is seized. I like the comment about checking the PTO lever...sometimes it can be the simple things we overlook.
I had that happen on my max26... for no apparent reason the PTO lever all of a sudden wouldn't go all the way back to push in the safety switch... this was after I'd been running it for a few hrs... I
shut if off, then went to start again and it wouldn't start... just got lucky after about an hr of frustration and happen to push the PTO lever back and turn the key at the same time...
walla it started... have to do that all the time now...
/ 5570 - Serious problem and I need some good advice #28
I've said many times to start with the easiest answer to a problem and work up from there. Rarely is a complex problem the answer. I've heard of guys tearing into a tractor only to learn they had a PTO switch malfunction.
/ 5570 - Serious problem and I need some good advice #29
Either that or take it to a shop that will repair or even rewind it. There are lots of those types of shops around that rebuild starters, alternators etc.
Well, the saga continues. A new starter was installed, but tractor still would not start. It attempted to engage but, unlike the OEM starter, each time the key was turned it was followed by a brief mild screeching metal-on-metal kind of sound....not a good sound at all. Now the ring gear will not budge. The best tractor mechanic I could get to look at it is convinced it is the main bearing, but we need to remove the oil pan to confirm. Now, for those of you wondering why this has not yet happened, you must understand the oil pan on a 5570 is structural and solid cast iron. Heck the tractor has to be darn near split in order to remove it - seriously. Because the machine is not "indoors" - only under a shed - I have been hesitant to get this deeply into it. As I pondered on just how to get a look at the inner workings without committing to a major motor tear-down, I was reminded a good friend of mine has a nifty little camera for looking inside engines and other tight spots. He is bringing the gadget over in a few days so we are going to drain the oil, again, and take a look with this camera before going any further. If the oil pan looks like a glitter factory, well let's just say Santa's sleigh may be a considerably over-burdened when he drops by my place.
Honda UTV (A56859)
Honda UTV (A56859)
24in pin on excavator tooth bucket (A61307)
24in pin on...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
CFG Industrial H12R (A60463)
CFG Industrial...
