OP
jcraftenworth
The DK series could still be a contender at ~63" min. width, but the MX is too wide and 2WD K-series is exactly 66" wide with R1s (per brochure). Width specs will have to be manually verified, but the big spec that stood out to me was your 3PH lifting capacity.
Safely and comfortably carrying 1500+ lbs on the 3PH and pulling wider/heavier implements puts some of the smaller CUTs into the "barely" or "ain't gonna do it" range. Your unique situation literally and figuratively narrows the options. After buying too big, I'm personally concerned about too small... if there is a compromise, would rather it be paying a little more for can vs. can't do.
P.S. you forgot the engines for all the little tools like weed trimmer, chainsaw, rototiller, chipper/shredder, pressure washer, and maybe a generator, etc.! Agree, they add up and would be nicer to have one a single power source and multiple interchangeable implements. Somebody wiser once cautioned that frankentool may do everything ok but nothing well... so now my bank account is smaller and storage/maintenance needs are bigger for a bunch of low hour engines and single purpose tools.
it's not quite as extreme as it seems because the transplanter has wheels that help support the weight, but some 3 point lift assist is necessary to level the thing out, and if you are going over some gnarly terrain, it would actually be advantageous to be able to lift the whole thing off the ground with the 3 point lift. Luckily it's flat as a pancake around here so that hypothetical doesn't come up too much.
Here's what we're talking about: Water Wheel Transplanter Farming Equipment :: Rain-Flo Model 16
