Pricing a DK5510HS
/ Pricing a DK5510HS #1
BlessedMess
Roll Tide!
Kubota MX5200
Spent some time this weekend at a few different dealers -- orange, red & green -- and was unexpectedly most impressed with the DK. Likely in the top 2 of the open station options being considered --
PROS: light weight (truck limits towing capacity), quiet engine, economy PTO, strong warranty, competitive loader/3PH specs, reasonable cost backhoe option
LOWS: light weight (traction limited w/o ballast), no telescoping link ends, notchy HS lever... thinking LS' powershuttle lever is industry gold standard, and all Kioti dealers are ~2+ hours away
Does $23.9k with loader and one remote + tax sound about right? And $6.5k for backhoe (after rebate, incl. install). Believe these are all cash prices. Many thanks in advance and for any free advice on Kioti tractor shopping.
p.s. I also tried a SS NX4510 and surprisingly liked the DK better (quieter, PS, ePTO, loader joystick placement). They also have an old stock but new 7 hr NX4510HC + loader + one remote for $27k, which is tempting except weight is higher and PTO hp lower than preferred.
/ Pricing a DK5510HS #2
I recently purchased a DK5510HS for myself. Before that I've had a LS U5030 and XR4046.
I've only had my DK for 2 weeks, just enough time to barely put 30 hours on it but so far I love it. Pretty much agree with your pros/cons. I filled the tires but will probably build a 3pt rack for suitcase weights for a little extra ballast when needed.
I added 2 remotes, 3rd function valve, rubber deck mat, front and rear work light kits and quick link 3pt arms (uses the euro style 3pt arms with removable balls). All worthwhile upgrades.
I'm not going to comment on pricing but will say this tractor has far exceeded my expectations so far. I don't think you'll be disappointed.
Appreciate the comments and upgrade suggestions... thanks man, and also a big congrats on the new tractor! Any chance some pics, especially of those upgrades and end links, are coming soon?
Also, do any owners have any feedback on the DK's DPF regen characteristics, e.g. frequency, duration, and/or performance changes (if any) during regen?
/ Pricing a DK5510HS #4
Here's a pic from last week, I will grab one of the 3pt arms when I get a chance.
/ Pricing a DK5510HS #5
The arms are designed to leave the balls on each implement but I have a few sets and just switch them around. Makes hooking up real easy. Especially on larger implements.
/ Pricing a DK5510HS #7
Question on the grapple.
I know we have four connections for the FEL did you have to install another one to be able operate the grapple jaws for opening and closing ?
Did the original quick attach plate of the FEL fit on this grapple?
What make and size is your grapple?
Those arms. Did you have to change the whole arm or is it just a kit that fits on the existing telescopic 3PH arms?
Thanks
Gilles
/ Pricing a DK5510HS #9
Comments below
I know we have four connections for the FEL did you have to install another one to be able operate the grapple jaws for opening and closing ? I installed a WR Long 3rd function kit to run the grapple
Did the original quick attach plate of the FEL fit on this grapple? The grapple came with a universal skid steer mount. So far it's fit on the 3 tractors I've owned
What make and size is your grapple? See my comments in the reply above, I believe it was made by Titan. It's a 66".
Those arms. Did you have to change the whole arm or is it just a kit that fits on the existing telescopic 3PH arms? My DK did not come with telescoping arms, just standard fixed arms. These are new lower arms that replace the factory ones.
Thanks
Gilles
Appreciate all the pictures and information, Jeremy. Beautiful tractor -- she looks like quite the workhorse, esp. with that grapple!
/ Pricing a DK5510HS #11
Jeremy, have you maxed out the fel with that grapple yet? I'm thinking of a similar configuration and I'm wondering how much extra ballast I need in the rear.
/ Pricing a DK5510HS #12
Thanks to this thread and JLinders comments I just pulled the trigger on a DK5010HS with all the options mentioned plus a canopy and minus the lights. Kioti extended last years incentives and added in free quick link arms and rear remotes. Whole package 24k. The 5510 is not included and would be $1600 more.
/ Pricing a DK5510HS #13
We might get to experience this model at the same time .... going over the fine details of ordering one from my local dealer.
/ Pricing a DK5510HS #14
Congrads! That is a great price! I really like your set up.
/ Pricing a DK5510HS #15
I have loaded R4's and it's not enough by itself. With my flail on the back it's perfect which weighs 650lbs but the center of gravity is farther out than a ballast box would be. I plan to build a rack to use suitcase weights which would give me some adjustment but I'd guess 800ish pounds with the loaded tires would be about right.
/ Pricing a DK5510HS #16
Congrats, you will love that workhorse.
/ Pricing a DK5510HS #17
Gentleman, Kioti has upped the rebates on the DK5010 only for January. Same applies to the NX5010 ROPS model. (50 hp models only, the other DK and NX models do not apply). Plus Kioti extended the 6 year powertrain warranty promo.
If you're able I suggest you pull the trigger this month and save yourself some $$.
/ Pricing a DK5510HS #19
JLinder
What size are the balls I need for the DK 5010 quick connect lift arms on the 3 pt? Visited TSC today and bought the wrong size. Thanks
/ Pricing a DK5510HS #20
JLinder
I replied in your other thread. Message me if you need help.
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2014 Evinrude 2-G 225 HP Outboard Boat Motor (A66738)
2014 Evinrude 2-G...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
2010 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2010 INTERNATIONAL...
2005 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A66736)
2005 Mack CH613...
