Buying Advice Looking at the MF GC1720
   / Looking at the MF GC1720 #1
Catman8
Gold Member
California
Massey Ferguson 30B, John Deere 2032R
Hello, no one likes surprises after a purchase, I bought a ski boat and to my surprise i receive a bill each year for a luxury tax and other state taxes and of course the crooked salesman is not going to tell you about these things.
I live in California, is there any hidden fees for owning a tractor that the salesman is not going to tell me about, like does it need a smog test every four years or any other state taxes.
If I bought a MF from another state will it have all the same emissions standards as one bought from California?
I rented a small tractor with a clutch once and it was so annoying shifting from forward to reverse but it did have a lot of gears to select from, the MF GC1720 only has two speeds, do you feel that your giving up gear selection for ease of use with the hydrostatic transmission?
Does forward and reverse have the same speed?
I own a MF 30B and was looking for a backhoe for it and a tractor mechanic told me that backhoes twist the frames of tractors so bad that all they do is damage your tractor and cause leaks to your drive train, true or false?
I hate surprises so any info would be great, thanks.
   / Looking at the MF GC1720 #2
I can't answer you CA specific questions...because I don't like in CA, never have. But I'd be surprised if the GC1720 was anything but identical in every state. I'm also not sure its the salesman's job to tell you about the taxes or fees that you'll have to pay to the state in which you live, unless its related to the purchase (like sales tax, or registration fees for a vehicle, etc). Though it would be nice if they told you everything they have learned....
I'm not sure you fully understand how hydro works on the MF and other tractors. It has 2 ranges, You can think of it like a pick up in that respect, you can have hi or low range. You get infinitely variable speed within the range (up to some max) via the pedals on the floor. The difference between the tractor and truck stop there, the pedals do not control throttle, just speed. If your throttle is low, you won't be able to go very fast or will stall the engine.... Forward has a faster top speed than reverse. The number should be on the website.
On your last point, about the backhoe damaging frames, I think your mechanic is making things up!
Thank you for responding, your right I don't understand how the tranny works, are you saying the more you push on the pedal the more power you have?
   / Looking at the MF GC1720 #4
Catman8,
Power is controlled bybthe throttle increading the rpms ofbthe engine.
Speed is controlled by the hydro pedals. The benefit to a hydrostatic drive system is nimbleness of movement, a fine touch in going very slow or in switching from forward to reverse, and drag when you want an engine braking effect on hills and slopes.
As to the mechanic saying a bh twists the tractor . . if that were so . . would there be a 5 year warranty or 6 ir more on the competitors ?
   / Looking at the MF GC1720 #5
I think Axle did a decent job on the explanation. Throttle control available power, pedals control speed. If you find yourself in a situation where the engine begins to bog down, don't press the pedal harder, raise the throttle. If throttle is all the way up, back off the pedal.
A common thing I've seen among first time hydro drivers is they will be going up a hill in high range. The tractor will begin to slow, so they press the go pedal harder, the engine bogs, the tractor slows more, they press the go pedal harder....next thing you know the engine stalls. All that needed to happen was either up the throttle, switch to low range, or just back off the pedal.
I highly recommend you get out and drive some hydro tractors. For loader work, or anything that requires often change of direction (forward/reverse) or speed control, you cant beat the hydro!
My operators experience is with a Cat 935 track loader excavating swimming pools for five years in San Diego and that machine has lots of power, that career ended due to tinnitus (ringing of the ears), I then bought five acres in the country and purchased a used MF30b and the injector pump failed, took it apart and had the pump fixed and in my travels at work I lost all the fuel lines, so that tractor has been sitting idle and I need to get it working again so I do have a big tractor, a big tractor is nice but has its limitations in tight areas.
So now I'm looking for a small tractor for small jobs, I am use to the bucket controls being next to my hip, the location on the GC1720 is forward were you need to lean forward and looks very uncomfortable, I'm thinking you could make a new lever that is closer to the operator.
I'm sure you guys have ran into situations were you found the GC1700 series could not perform some task or had its limitations, could you share some of those experiences, do you find the tires spinning because they are not big tractor tires.
I guess what I'm trying to ask is this an underpowered toy, or do you feel it serves its usefulness as it was intended.
   / Looking at the MF GC1720 #7
I've definitely run into its limits. In fact, right now, I have some rocks that I would like to move, but can't. That being said, I've done 99% of the work I wanted to get done. I also use my GC1720 as my mower, so I wouldn't really want to go any bigger (heavier). If comparing to a Cat 935, you'll be disappointed in the capability, you will need to realize these are two VERY different machines.
Thanks for the reply, I was not comparing the Cat to the MF GC1720, I was trying to decide if I should go with a garden tractor vs a compact tractor, but my thinking is if I get my MF30B working I will have a big tractor for big jobs that the GC1720 can not handle.
Does your GC1720 have the back hoe on it, I rented a full size backhoe once and had a terrible time using it, I could not dig anything, I just pulled the machine around because I did not know how to operate the hoe properly. Can you dig a trench with yours or does the ground have to be really soft.
   / Looking at the MF GC1720 #9
I would not in any way consider my GC1715 as a toy. In fact just the reverse . . because it is nimble it is still important to remember that it can break things easily.
Also . . Every size of tractor has it's limitations and a GC17xx is no different. I've been surprised just how much I can do with my GC . . Whether its plowing/bucketing deep snow or lifting heavy pallets.
I opted to not buy a Kubota BX or a JD 1025/6 or a Mahindra once I met and tested the GC17xx.products.
I don't have "spinning wheels" as an issue. In fact I didn't expect I could drive on my lawn with 6 or more inches of snow more like an atv than a tractor . . And that is with turfs and no lawn damage (except during spring thaw of course).
And once I add a grapple and remote to the mix there will be only one item remaining . ..a unique plow for my fel. If there is one limitation I have . . I still have to work more on my "level sightedness" relating to my fork usage. I still leave too many marks on concrete or lawn because the forks are tipped forward or backward too much near ground level when I'm dropping off a skid . . but thats my weakness . . not the tractors lol.
Thanks for everyone's advice, I just noticed the MF GC1720TLB at the dealer has a DL95 loader and a CB65 backhoe, but the brochure he gave me shows a DL100 loader and a CB05 backhoe. Why is that?
   / Looking at the MF GC1720 #11
The brochure is dated . . the dl95 and cb65 1st came out to replace the dl100 and cb05 in later 2014. Nothing wrong with the prior attachments . . but several things right about the newer ones. If you read on tractorbynet in numerous threads it talks about the differences and improvements provided by the new supplier. One noticeable difference is the fel lifting capacity is considerably more if you get the "true" dl95 loader numbers instead of the older numbers with the new model description.
   / Looking at the MF GC1720 #12
Catman8, you wrote:
"I was not comparing the Cat to the MF GC1720, I was trying to decide if I should go with a garden tractor vs a compact tractor, "
I sense from that statement that you haven't test driven the gc product . . Because a garden tractor does not do what a sub compact GC product does . . and none operate or feel like a GC1715 or GC1720.
My experience is with large tractors and I'm familiar with their power, I have not had a chance to ever use a GC tractor in real life experience, I did drive it around the dealer lot but that is not going to show me the capability of the machine. if I could rent one for a day and be able to use it that would be great, but I doubt the rental companies have a MF GC1700 series to rent. i know its impossible for someone to explain the power or capabilities of a machine in a chat forum, but I do appriciate all the advice and the forum is very helpful.
   / Looking at the MF GC1720 #14
So have you asked your dealer if they offer a unit they can drop off at your location to test for a day ? I had 2 offer that to me.
   / Looking at the MF GC1720 #15
I would head over to youtube and see what folks are doing with their SCUT sized tractors. Looks for videos of the Massey GC line, but also the equivalents from John Deere, Kubota, etc. They all have similar capabilities. For example, you'll probably find a video of a Kubota BX25 trenching, simply because there are more of them out there, but the Massey should be able to do the same thing. This will give you a good idea about the capabilities of this sized machine.
AxleHub, no the salesman did not offer a demo, but I'll ask him. Thanks for the idea.
Fiziksgeek, I'll check out you tube. Thanks for the idea.
I recently came across a website tractor house.com and there is a dealer Bruno's tractors out of Cabot, Arkansas, he's advertising a MF GC1720LTB FOR 17,200. Free shipping and no tax. Does anyone have experience with This dealer or have opinions on this price.
Ok, I contacted the dealer in my area and he said sure we can bring the tractor out to your property for a demo :) So next week I will see what a garden tractor can do, or shall we say, can't do.
   / Looking at the MF GC1720 #19
If you have dirt work, projects or a larger property to maintain and you have the money for a Subcompact they are night and day better than a GT. GTs are pretty limited as you know. If your calling the GC a garden tractor I think your about to get surprised... GC is far superior and more useful in almost every way.
I can't think of very many reasons for owning a GT any longer with all the nice ZTRs out there. To me the decision would be ZTR or SubCompact. I pushed Snow/gravel with my commercial ZTR for several years. 1108091349.jpg
   / Looking at the MF GC1720 #20
I personally like product that is designed and built by a single manufacturer (engine and tractor).
I came to thst thinking because each of the examples I'll mention have certain characteristics that others don't:
Kubota, Yanmar, Iseki (Massey). They built their long term reputations on engines (multiple decades for thers) and then a decade or more building tractors as well as engines.
In Massey's case (iseki) the only things they don't do themselves is the fel, backhoe, and mmm choices.
All three have forward engine cooling in their scuts which others don't offer. Yanmar weakened some of their choices with their latest scut choice (221) but strengthened with the 3xx and 4xx choices.
Kubota makes great machines but they've been steadfast in certain things that I think need updating.
Meanwhile I felt Massey really stepped to the plate and corrected or improved greatly. A new suppluer for the backhoe and fel really increased their lifting capacity over their good prior supplier. They kept their frame size but their fel capacity went up up up in weight handling. Better pump flows at lower rpms remind you of the yanmar supplier method on the sc2400 series - so the GC1700s can have great power without high rpms. But we all gave different perspectives and needs.
I wanted nimble but strong with considerable operator comfort . . I found that last late spring with Massey (while I was definitely looking for BX Kubotas).
Catman8, don't take an onsite demo for granted. Preplan a series of things to do on the demo and don't try to spend a lot of time on any one thing. Pre-stage things if you can . . . don't "justwing it". This is your chance but a salesman isn't going to want to be there 2 or 3 hours either.
Jmho
New Holland Basket Rake (A56438)
New Holland Basket...
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
240156 (A56859)
240156 (A56859)
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
