Which fluid are you using in HST models?
/ Which fluid are you using in HST models? #1
mike35549
Walker Co. Alabama
Mahindra 2538 with FEL
My manual list several different preferred brands but basically just says has to meet GL-4 specs. The reason I ask is I had to buy a couple gallons because of a leak and what come in my tractor was not the Mahindra branded stuff because it is red in color and what i drained out was normal UTF color. Also the Mahindra stuff is $18 a gallon. So which brand are those of you with HST using and did you notice any more or less whine from transmission when you changed it. Was thinking I will just go with the Rotella HD or travelers brand from local tractor supply anyone use either of those.
/ Which fluid are you using in HST models? #2
I've been using TSC premium for a year now, very satisfied. No noticeable increase in whine.
/ Which fluid are you using in HST models? #3
Ditto, used 10 gallons of TSC Premium Universal fluid in both of the changes I have done on my 5035 so far. Will do the same with my 2555 if I ever get some hours on it.... [ with Mahindra sourced OEM filters ] Had some rear end/transmission whine on the 5035 'till the gears lap'd themselves in, but didn't or don't notice any other whine.. maybe because of the big grin I have when using the HST closes off some of my ear canals... :)
/ Which fluid are you using in HST models? #4
Ditto. I have a shuttle/gear not that it matters much. It just has to be formulated for later model machines with wet brakes and such. The TSC premium stuff list's Mahindra among many others on the back label.
From the description
Provides superior protection and performance for modern farm equipment
Employs a common sump to lubricate hydrostatic transmissions, differentials, wet brakes, hydraulics and final drives gears
Traveller Premium Universal Tractor Trans/Hydraulic Fluid - For Life Out Here
Many cheaper UTFs don't have the necessary additives for wet brakes, HSTs etc.
/ Which fluid are you using in HST models? #5
So, to summarize, a total of three old decrepit ex Agency has beens swear by the TSC stuff..... Life IS Good.... !!!!!!!!!!!!!!!! :)
/ Which fluid are you using in HST models? #6
Hey ! I resemble that remark !
/ Which fluid are you using in HST models? #8
/ Which fluid are you using in HST models? #9
/ Which fluid are you using in HST models? #11
You just hit the nail on the head, buddy....!!!! :)
I would have thought more people would have used the Rotella HD fluid. Good to hear the Traveller brand is working good since it is readily available.
/ Which fluid are you using in HST models? #13
And a lot less $$.
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
Hydraulic Breaker Excavator Attachment (A61572)
Hydraulic Breaker...
Lot 602 (A62613)
Lot 602 (A62613)
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
