L3130 HST TRANSMISSION OIL
/ L3130 HST TRANSMISSION OIL #1
inveresk
Saltspring Island, BC, Canada
Case CX31B ZTS
My manual advises use of UDT, UDT2 or GL-4 transmission oil. GL-4 oils vary considerably in viscosity. I'm coastal BC, similar climate to Seattle, so what viscosity would be appropriate?
/ L3130 HST TRANSMISSION OIL #2
Here in the States, Kubota owners are most likely to use the recommended "Super UDT2" factory transmission fluid, although some favor other non-Kubota premium fluids, such as Amsoil. These are all premium-priced fluids that seem to promote smoother, more consistent HST operation and seem to work well regardless of the climate. It looks as if Kubota Canada has somewhat different names for their fluids and I don't have any idea if your choices are comparable to those offered south of the border. Maybe a dealer would have more information. All I could add is the opinion that choosing top-quality fluids for use in my tractors has always made sense to me.
/ L3130 HST TRANSMISSION OIL #3
Isn't the good stuff in Canada called Premiun UDT?
I always forget!
I can't imagine using GL-4(gear oil)in the transmission on your tractor.
Maybe in the front axle is cool.
Kubota hydros like and are worthy of the good stuff!
/ L3130 HST TRANSMISSION OIL #4
Here in northeastern Pennsylvania, the temperature ranges from -10 in winter to the mid 90's in summer. The local Kubota dealers in the area say to use UDT2 or Super UDT2 fluids. For garage kept tractors, UDT is also permissible. When my L3430 HST was new, I used UDT since the tractor was kept indoors. I don't remember why but I switched to UDT2 when I did the first oil change. HST tractors are well known for their gear whine and I noticed a distinct increase when using the less viscous UDT2. I also noticed a slight increase in the bleed down rate for the FEL and 3pt hydraulic cylinders, likely due to the slightly thinner UDT2 oil. Neither of these issues are a problem for me so I continued to use UDT2 in the L3430 until I traded it last spring. I also use UDT2 in the new MX5800.
I have no experience with the GL-4 oils so I can't help you there. I do suggest that you use a premium oil recommend by Kubota to prevent the possibility of voiding any warranty that may be in effect.
/ L3130 HST TRANSMISSION OIL #5
Super UDT is worth it for me and better that UDT. I tried a couple different brands and SUDT made the least noise and shifted the smoothest. I can't even imagine GL-4 in that beautiful hydro.
/ L3130 HST TRANSMISSION OIL #6
Since I switched to Amsoil, tranny seems to be running cooler and less whinier.
None of the Kubota fluids are synthetic and that was the deal breaker for me.
/ L3130 HST TRANSMISSION OIL #7
Maybe double check that on Kubota SUDT2.
/ L3130 HST TRANSMISSION OIL #8
just today received 10 gal. sudt2 for my 3rd oil change---expensive???? **** YEAH--but well worth it to me
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
Kubota M4700 (A60462)
2014 CATERPILLAR 140M2 AWD MOTORGRADER (A62129)
2014 CATERPILLAR...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
