Picking concrete with FEL
/ Picking concrete with FEL #1
willysmb
Grand Rapids, MI
Massey 1736
I am buying a tractor and a house. The house has some old concrete sidewalks that I want to remove. Obviously this would be easy work with a backhoe but I am pretty sure I am not going to purchase the backhoe with the tractor. I was thinking that perhaps some type of fork or spike on the front of the FEL would make this easy work as I could push the spike under the concrete and then lift the concrete up from underneath.
Anyone have experience with this or recommend a good attachment? Would normal forks work fine?
/ Picking concrete with FEL #2
Forks, not the type that clamp to the bucket, but the type that replaces the bucket. Make sure the fork is rated for the breakout capacity of your tractor.
Thanks, that is what I figured. Yes I will be getting a set of real forks for the tractor. I have about a million other uses for them as well.
Hey, another Michigan person!
/ Picking concrete with FEL #5
A grapple works very well also. I've moved a lot of concrete with mine as well as a little bit of everything else. You can grab pieces easily large and small with one.
/ Picking concrete with FEL #6
Just pray that there wasn't rebar embedded in it when the concrete was placed.
Been there, done that, got the t-shirt ...
/ Picking concrete with FEL #7
One caution is that you want to be very careful about loading one side of the FEL, and not the other....easy to do with forks. What happens is you lift up, or push, on one side and it bends the torque tube between the left and right sides of the FEL. When that happens it's no longer level, and you have to try bending it back, or cut the torque tube, level everything, and reweld it.
/ Picking concrete with FEL #8
I think Id be saw cutting through the slab pieces big enough to get into the bucket and carry them away that way. The concrete saws are cheap to rent, just get a dusk mask, ear plugs, and glasses.
The pieces are all small enough to pick up with the bucket, I just need to get underneath them and get them out of the ground. I figured it would be easier to do this with forks rather than the bucket.
/ Picking concrete with FEL #10
It should be...
First rule, be gentle.
Then start forks at edge of concrete piece at a more steep angle, then curl and apply just a tad of pressure on the hydro forward pedal as the curl continues to level This should get under them fairly easyily. Make sure that your load will be evenly distributed (not a lopsided load).
When under them, curl back and lift. Don't lift them very high, just get them off of the ground. When carrying heavy loads never travel with the load above the hood in any case. If you need to load into a dump truck or something high.. line up and make sure you are stopped then lift carefully.
Traveling with a heavy load too high is the #1 reason for rollovers.
/ Picking concrete with FEL #11
You haven't mentioned a need for forks otherwise? I say use the bucket. The process will go a long way in teaching you where the bucket lip is at all times. Very doable, just takes some practice. :)
/ Picking concrete with FEL #12
I used a bucket to do this exact thing. While it kinda worked - it wasn't the best tool for the job. I think forks will work a a lot better, but it's a lot of force - and it's possible to tweak your loader or QA if you aren't careful. Why not just spring for a grapple? I think it would likely be your best option.
/ Picking concrete with FEL #13
Well, I'm glad to see that you have your priorities in proper order. Get the tractor first, the house can come later with whatever money is left over!
Haha, we close on the house end of the month. Going to buy a tractor shortly thereafter.
I can buy whatever I just wasn't sure what was the best for the job.
I have tons of usage for forks. I'll be getting a set either way.
/ Picking concrete with FEL #18
The before and after, spent about 10 hr. cutting up a 4-5"x16'x32', cement slab into 2'x6'ish with a diamond walk-behind saw. Then used home made clamp-on folks to move them one at a time, some broke but that's ok. they made a great/good 4' high retainment wall.
Nice, That looks good. Fortunately mine is all small pieces.
/ Picking concrete with FEL #20
The guy who put in my neighbor's concrete driveway ripped out the old asphalt one with the loader on a 4WD Kubota. I estimate it must have been around 40 hp. There was some wheel spinning but, he got it out. I don't remember whether the bucket had a tooth bar.
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
Mounting Plate Skid Steer Attachment (A61572)
Mounting Plate...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
Generac Generator (A61572)
Generac Generator...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
