How do you organize your towing accessories?
   / How do you organize your towing accessories? #1
CanDo
Michigan
JD790
To start it off, here's a way that I use to handle multiple hitch sizes.
To make a short story longer, let me explain that many moons ago I pulled my first trailer which had a 1 3/4" ball. Naturally, the next trailer I got had a 2" ball and then of course I got a bigger enclosed trailer which has a 2 5/16" ball. Three hitches is a pile of metal so I kept them in the garage and just pulled out the appropriate one when needed.
Well, there are always those situations when I was out and about and a need arose to pull a trailer - but the needed hitch would be back home in the garage. Well, I started carrying the 2" with me in the truck since that was the one that was called for most often. Yep, you guessed it, Murphy's Law would kick in and the trailer to be moved would require one of the others... Urgh! A few years back my thoughtful son gave me one of those "convert-a-ball" systems which is pretty slick. Now I could carry all three sizes with me in cardboard box (later a plain wooden box) which certainly was more manageable. Now all I needed to do was dig out under and behind all of the other stuff that I carry in the truck to get to box with the convert-a-ball hitch. Not bad, but there had to be an improvement that could be made. Here's what I came up with: A trailer hitch storage caddy that is mounted on the rear of the sidewall of the pick-up bed just inside the back tailgate. It's compact, out of the way - yet very accessible and keeps things organized.
Hitch box - closed.jpg Hitch box - open.jpg Hitch box - Nutsert in truck.jpg
Details: The box itself is built out of some glued up and pinned small pieces of Baltic birch plywood with the interior dividers made out of various scraps that were cut, carved and glued and pinned into place. Once put together I drilled a hole through the back of the box and then stood it up against the onto the side wall of the back of the truck bed and then drilled a hole through the bed and inserted a Nutsert to which the box could then be bolted onto. If you look at the pictures above you can see that the weight of the box is resting on about a one inch high block which, not only carries the bulk of the weight, but also keeps the box off the bed in case of water intrusion. Total cost has to be about $6. I bought the draw hasps ($2.99 from Menards- less the 11% rebate) and other than digging through the wood scraps, I had to use a little glue, a few 18 gauge pins and a Nutsert out of my Nutsert kit.
Here's a better picture of the layout inside of the box.
It's now seen a few years of hard use and the box has held up well!
A few months back I made one for my son that fits in his VW Jetta wagon. You can see that it's quite a bit thinner and just lays on the bottom of the boot under the floor. A bit different in design to accommodate the smaller hitch (although it only has two balls) and to fit in a smaller space. The first pic shows the layout of the box which is just sitting on the floor. The box had to be thin enough to fit under the floor so the inside of the lid is sanded out just a bit to clear the widest part of the hitch. The second picture shows the box in the boot.
Hope this gives someone an idea.
Love to see what you've done.
   / How do you organize your towing accessories? #2
Nothing like yours I have a truck box in back of my pick up with my chains and binders.
   / How do you organize your towing accessories? #3
I have one of those adjustable height balls that stays on my truck. It's also a 2-2-5/6 combo ball. I've also have have one of those 3 in one balls. I use that one to hook a chain to and such as that so I don't scare up my nice aluminum one. My other dozen balls I just toss somewhere. I've never put much though into storing them. I have one trailer that I use sway bars on and I keep those on the trailer.
   / How do you organize your towing accessories? #4
Nicely done. Very clean design and layout.
I'm not so organized. My dually has a utility bed, back bottom box is hitches, chains, and ratchet binders. Normally have a pintle hitch in the receiver, and carry ball hitches with a few different drops in the box.
   / How do you organize your towing accessories? #5
I only use a 2-5/16" and 2" ball on my trailers. I have a solid/forged 16k drawbar for my 2-5/16" ball and a plain jane Reese 7k interlock style drawbar for the 2" ball. One rides in the receiver on the truck, the other rides in a hitch bag like this:
The hitch bag, chains, and binders all ride in the bed of the truck in a plastic tray like such:
   / How do you organize your towing accessories? #6
I just keep my stinger and balls and shackles in a milk carton carrier tied to the back driver's side corner. Where I live no one rips this stuff off and it is handy enough to keep in sight. Last thing in the world I would do is leave hitch and ball hooked in the receiver when I don't need them. Makes for easier smarter and safer parallel parking when in town. Binders and chains ride in a milk carton container attached to the front of the trailer. Aint fancy but works for decades.
   / How do you organize your towing accessories? #7
I learned about stinger rusting into hitches the hard way with my last truck, so I always take it out with this one. Since a plain straight stinger seems to work for my current trailer, I have one of the jname brand tri-ball ones. I also picked up one of the all-one-piece receiver pintles. Both live under the driver's seat, and can be accessed from the front or back. There are a couple of crossbars and bumps on the floor that keep them from sliding out, but they do clunk on big bumps. Spare hitch pins, clips, wiring pigtails and testers are in the center console. Ratchet straps are in a plastic tote behind the seat, chains live in the garage.
   / How do you organize your towing accessories? #8
Very nice idea. I worry sometimes with the SUV having that chunk-of-steel projectile inside with us but I won't leave it in the hitch either. Leaving it loose in the pickup box worries me also. I did a quick light roll in snow with a car when I was younger and you wouldn't believe the dent a very small bottle jack made in the roof! Glad my head wasn't in the way.
It seems that you all have come to the same conclusion that I have and that is you have to carry your capability with you rather storing at home.
I am a bit jealous though of hslogger's ability to leave stuff in an open truck bed... around here it's not bad, but there are just enough as#:mad:les around to require one to lock things up. Heck, three decades ago I never locked anything - car, house, nothing! Still wouldn't need to for 99% but now we have that very small group that seems to be bolder and more aggressive in thinking that what's not theirs aught to be theirs.
Ouch!
John Deere 757 Zero Turn Mower (A50860)
John Deere 757...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2012 Hyundai Genesis Sedan (A48082)
2012 Hyundai...
2015 Ford Explorer SUV (A48082)
2015 Ford Explorer...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
