Just got a new trailer, and may be in trouble with GVWR. Advice needed.
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed.
It sounds like you need to sell the trailer and buy a 10k. Or 14k trailer to be safe.
Thats what I am doing. Listed the 7k trailer on craiglist yesterday
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #32
Well I hope you have better luck then me . I was selling a 16' 10k trailer for 2600 and no takers! Bought trailer a little short.
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #33
Who's dumb enough to haul a trailer and tractor going 85mph!
Just 'cause your tires are rated at a higher max that you would really go, doesnt mean you must go that fast.. The higher rating means that you have more headroom for load rating and heat generated which makes for a safer tire and less chance for a blowout at speed.
For example, passenger car tires are rated at above 100mph, but that doesnt mean you must drive 100mph :)
This is also why LT tires on a trailer are usually better than ST tires. ST tires, since they arent meant to carry live people, are rated much closer to the max the tire will actually handle, especially at speed. Being able to handle 3500lbs at 65mph is actually much weaker than being able to carry 2000lbs at 100mph.
This is also the reason Regional truck tires are cheaper than Long Haul/OTR tires.. The Long Haul tires are rated to handle the load for thousands of miles at (usually) a higher speed and with more heat buildup, while the Regionals are not as they are meant for short distances and have a much higher chance to blow due to speed and heat when used in a Long Haul capacity.
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #34
Well explained. I have little respect for ST tires.
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #35
I run 60 to 65 on the highways , usually with my travel trailer , you would be amazed at the pickups towing campers blowing by me like I was standing still .
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #36
I've saw 85mph on the speedo in my Super Duty pulling my GN grossing 24K lbs. Some would call that stupid. I would call it insane if I was running ST tires rated for 65mph. Which I do not.
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #37
That might be me :D:D
Go fast or stay home. I drive like I like my women, fast and hot. :laughing::laughing:
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #38
I pull trailers with heavy loads at the 80 mph speed limit on our interstates on a regular basis. Did a few hundred miles of it this week in fact.
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #39
Would it be alright if I use that line????? Love it. :)
/ Just got a new trailer, and may be in trouble with GVWR. Advice needed. #40
iDrive TDS-2010H...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
2016 Hyundai Veloster Hatchback (A59231)
2016 Hyundai...
2018 Ford F-350 (A55973)
2018 Ford F-350...
1998 Wabash National 48ft T/A Flatbed Trailer (A59230)
1998 Wabash...
