   / Share Pics of People Hauling or Towing Something Wrong #4,171
What did you load the blocks with?
Skidsteer with a 2,300lb rated lift capacity. It's a radial lift machine so once I started lifting several feet up I could feel the back end getting light. I just assumed the lifting capacity was measured at the pin and my load in front was reducing that amount.
   / Share Pics of People Hauling or Towing Something Wrong #4,172
They put way too much effort into the trucks exhaust stacks...
I think that's the first pickup with stacks I have seen I actually like. They didn't run them up through the bed like everyone else where they can get dinged up by cargo, take up cargo space, and melt anything plastic within a foot of them...
   / Share Pics of People Hauling or Towing Something Wrong #4,173
Nobody with stacks through the bed actually haul stuff.
   / Share Pics of People Hauling or Towing Something Wrong #4,177
So, I don't know what they were hauling wrong, but they must have been towing something heavy. And this was found on a chevy 1/2 ton, small v8, no trailer brakes, with a burnt and slipping clutch.
   / Share Pics of People Hauling or Towing Something Wrong #4,178
There's a connector ramp here between two Interstates that has a downhill tightening radius. Posted 35mph for trucks but reasonable to push a car through at up to 50. Every few years a semi-load of lumber gets dumped halfway through that curve. Witnesses say they see lumber slide off the side or back of the trailer regardless of straps. (More likely loose straps so there's no friction between layers.) Photo - Similar.
Yeah, we have lots of lumber running on our backroads around here and every so often there's a tip-over. Seems a hard way to learn about the Coriolis Effect!
   / Share Pics of People Hauling or Towing Something Wrong #4,180
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
8 Piece Excavator Heavy Duty Attachment Set (New/Unused) To Fit CAT 301 (A59225)
8 Piece Excavator...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
Linde E25C 5,000 lb Electric Forklift  Cushioned 4-Wheel, Indoor/Outdoor Use **Needs Batteries** (A59225)
Linde E25C 5,000...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
