What antifreeze do I use.
/ What antifreeze do I use. #21
Wet sleeve or dry sleeve, I've always thought that SCA's were in order. In all the years we've run diesels we've never had an issue with cavitation. Some engines were more prone to it than others. My Workmaster does not have sleeves and the owners manual does not call for SCA's, just regular ethylene glycol. My Ford 4610 SU did have known issues with cavitation in the earlier blocks so Ford calls for SCA's. It is a parent bore engine. So what to do. I'm gonna stick with regular anti-freeze in my tractor until it is time to flush and then decide what to do.
/ What antifreeze do I use. #22
Google is an awesome tool.
HOAT=Hybrid Organic Acid/Additive Technology
OAT= Organic Acid/Additive Technology
SCA= Supplemental Coolant Additive
DCA= Diesel Coolant Additive
IDK= I Don't Know...(courtesy of my kids ;))
/ What antifreeze do I use. #23
Needed to look up something at work today, and came across this:
Learning Coolant Fundamentals
Starting with my gas engines, I went to extended life coolants a long time ago. For not much extra money, you get coolant that lasts so much longer.
Above article lists some of the history of coolant development, and explains the thermal advantages of organic acid products. The end of the article notes that you need to confirm with the engine manufacturer if nitrites are required.
Rgds, D.
/ What antifreeze do I use. #24
Green is about the most common antifreeze out there so I can't imagine youre not being able to find it. Not that it's the best just the most common. If you change types be sure to flush out the old stuff well.
Common "green antifreeze" has silicates. This is what will destroy your engine.
/ What antifreeze do I use. #25
I didn't say it was good I just said it was the most common. In fact I don't use it in my truck or our car. The tractor still has whatever the factory put in it.
/ What antifreeze do I use. #26
I got back recently from a little vacation, and a couple of you have PM'd me to answer this thread. I hesitate to do so, since the knowledge base already demonstrated in this thread is way beyond what I know about the actual chemistry of coolant. Just like oil threads, some of you guys really know your stuff!
What I see in the Mahindra manuals is that most if not all of the Mahindra tractors use a low silicate ethylene glycol with a max of 0.1% silicate. Even the mCRD models. Conoco Fleet, Shell ShellZone-LS, Texaco 2354/2055 are all mentioned as ok. We use a fleet approved low silicate ethylene glycol.
I do think proper coolant maintenance is often overlooked. The stuff wears out. This normal EG coolant should probably be changed yearly due to loss of effectiveness of the additives.
That doesn't mean there isn't a better coolant for these tractors. But this appears to meet specs. Probably just as important is changing it out regularly.
I'll listen in and see what the experts recommend. I do know that if you mix the wrong kind of coolants, you get a mess. I did this on a car once years ago. So if you change over to a different/better type coolant, I think you need to flush he system well first.
2020 KOMATSU D51PXI-24 CRAWLER DOZER (A62129)
2020 KOMATSU...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
832725 (A61166)
832725 (A61166)
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
